DF Pirate first run questions.
  • KartRacer
    replied
    Make-a-wake
    Do you think the speed looks correct in the video for 28 to 30 thousand Rpm.
    Where should I check to get correct readings. I should have amps on next run, which should help.
    Leave a comment:
    replied
    I'm gonna be real close saying that your loaded rpms are in the 28,000 -30,000 range. The 17k is just plain wrong............way off.
    Leave a comment:
  • KartRacer
    replied
    Logger set to 4 pole 180 is set to 3.5 degrees timing. Batteries were fully charged and at 25.20 volts.
    Running Delta Force Pirate 35" - Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
    Leave a comment:
    replied
    What motor kv and how many volts/cells???
    If your Datalogger is set for the wrong number of motor poles, it will be way off.
    Leave a comment:
  • KartRacer
    replied
    Shows on data logger download. Think it's incorrect?
    Leave a comment:
    replied
    How are you only getting 17k rpms?
    Leave a comment:
  • KartRacer
    started a topic DF Pirate first run questions.
    the boat ran well and was dry inside. Ran one minute and checked temps, all were low, mid 80 to 100.
    I removed the data logger and pulled the file, not sure if it is what i should expect but the rpm were lower than expected 17000 max. battery voltages were even with very little fluctuation. I did not get a amp report as I think i pulled the connector when I stuffed the logger in the pool noodle. Ran two runs with the only higher temps recorded with the temp gun at one of the motor connectors , 125f I think that connector fits looser than the others. Ill probably change it out.
    If the RPM is only 17000 then the amps would seem like they should have been high and therefore hot. So I am not sure if 17000 loaded is ok or if it should be much higher which would mean that the radio was not going full throttle.
    Also did not see any water spray from the exit ports, can the lines be hooked up incorrectly?
    I blew through the exit ports and they are feeding the rudder.
    overall a very successful first 1 minute then two minute runs just before dark.
    This weekend I should give it a good workout.
    Observations and input encouraged.
