When you mix A part and B part together. The hotter the 2 parts are, the faster the foam will rise. You can read all kinds of horror stories about foam. If done RIGHT it easy, quick, and very simple to add strength and flotation to a hull. If done WRONG you will destroy your hull in a matter of minutes. With that said, it's very easy to use this stuff.
Here's some tips, that I follow when I use foam;
1. Mix small batches, and let it set up for a good 10 minutes between pours or more.
2. If it's above 70 degrees, do your pours outside in direct sunlight. Cause the warmer it is, the faster it will cure
3. If pouring a large pour, have some holes for the foam to escape from.
If its to cold when you pour it, it can't fully cure. And when you take it to run. And its in the direct sunlight. When the foam gets heated back up, it can start to grow again and split your hull. Thats why I try to do any kind of foam work when its warm and in direct sunlight. Plus when I do my final pour,I'll leave it set out in the sun for a couple of hours, just to make sure its done curing.
