hot leads
  • namba98
    • 72
    hot leads
    ran my p spec hydro with ul1 motor castle 120 & 4s battery with cupped h10 prop
    speed 55+ 6 laps
    when i brought her in motor warm battery warm esc warm leads from battery to esc hot
    hot enough to melt pool noodle that was there for flotation
    any ideas???
  • Doug Smock
    • 5359
    Hi Dave,
    What connectors are you using between the battery and ESC?
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • line6
      • 510
      never mind misread
      Jason sims
      • namba98
        • 72
        i am using #5 gold connectors
        • Shooter
          Team Mojo
          • Jun 2009
          • 2752
          From my experience with props that big, the wires from the motor to ESC melt pool noodles easy (AQ60 esc). However, I've never had the batt wires get that hot?! What batts/gage wire on the batts are you running? Solder connections good on those connectors?
          • Raydee
            • 1619
            My Whiplash Sport 20 hull was coming back after short runs with hot wires and connectors when I was running a 1p setup. After switching to 2p everything is much cooler.
            Team Liquid Dash
            • jcald2000
              • 786
              When the voltage drops in the pack the motor demands more amps making the wire and connectors hot.
