Anomynous smoke?
  • mikeochs
    • Nov 2011
    • 239
    Anomynous smoke?
    Today i finally was able to run the new setup in my MC. I am now running a leo 4074 2000kv and a seaking 120 with 2s 5000 45 -95c x2 in series. My prop is a tuned m445. My first impression was holysh....t!!!!. It was incredibly quick out of the hole and a easy 54-57 somewhere in the vicinity. One provlem though, after a quick 1-2 minutes i brought it back in and when i took off the hatch there was a quick little cloud of smoke. not sure where it came from so i unplugged and looked everything ocer and nothin was hotand all still worked when i plugged it back in. I did notice and actuallt smelled like electrical smoke from the rx. Its still working so im not sure what happened. Do you guys think the m445 is to big. One thing the boat did do was torque hard to the right. Its trying to go right under hard acceleration. Any thoughts on this please
  • dana
    • Mar 2010
    • 3660
    Did you use oil on the motor bearings?
    • Chilli
      • 3204
      My first thought is the Seaking 120 is the weak link in that set up. I don't think it's going to last very long. A 180 would be a much better match.
      Mike Chirillo
      www.capitolrcmodelboats.com
      • mikeochs
        • Nov 2011
        • 239
        really you think it is to weak, I dont think it is pulling much more than 100 and no i didnt use any oil. None of the components were even close to being hot. Ill prop down a bit and try it again and ill put a little shot of oil in the bearing
        • mtbenjamin77
          • 885
          120 won't last with that setup. after a solid 6 laps WOT it'll be toast
          • mtbenjamin77
            • 885
            Just a little knowledge to share
            the ampere is a measure of the amount of electric charge passing a point in an electric circuit per unit time
            • iamandrew
              • 576
              If it was still working fine, if youd put some water tube around the stuffing tube and collet it could have been that.
              • jkr
                FE Addiction
                • 582
                +1
                The white foggy smoke in most cases is silicon tube.
                • dana
                  • Mar 2010
                  • 3660
                  Don't oil, sometimes certain oils like 3in1 can cause a small puff of smoke.
                  • jcald2000
                    • 786
                    Then kiss your bearings goodby!
                    • dana
                      • Mar 2010
                      • 3660
                      Not true
                      • T.S.Davis
                        • 6266
                        Use a thrust bearing. Without it all the thrust goes onto the rear bearing. Especially on the cheaper motors. I swear that smoke is baked bearing oil.
                        Noisy person
                        • electric
                          • 1973
                          Next time, put your fingers on the drive shaft. Sometimes you can get a super hot drive shaft caused by too much friction and the smoke is the grease burning up in the shaft.
                          • dana
                            • Mar 2010
                            • 3660
                            I should clarify, using appropriate bearing oil is good from time to time.
                            • dana
                              • Mar 2010
                              • 3660
                              I have run several brushless motors many, many times without ever oiling without issue
