Correct drill bit for slip fit
  • Electropilot
    • May 2012
    • 65
    Anyone know the correct drill bit to drill a shaft coupler for slip fit on a 5mm motor shaft?
    Have looked everywhere, but all I find is a #9 bit is 0.1960. and the person whom posted those comments on a different forum says that is a slip fit for 5mm, Is this correct?
    Thanks in advance:)
    Thank you much!
    Hydropilot
  • Basstronics
    • 2384
    I ordered a 5.00 mm twist drill "Cleveland" brand. Good US made quality. Reality is its a drill bit, so its going to drill slightly over anyhow. Just make sure to use plenty of cutting oil/lube and to use a proper center drill and predrill the center only about the size of the web of the final drill. This will yield the tightest hole you can get with a twist drill.
    For lube I prefer tap magic. If I cant get it just some solid LARD rubbed on the drill bit at speed. Dont laugh, it works and well (old Hungarian machinist taught me this).
    • egneg
      • 4759
      5mm is .1968 so you should be close.
      IMPBA 20481S D-12
      • Electropilot
        • May 2012
        • 65
        Awesome, thanks guys! Wanted to make sure before I bought a good #9 drill bit.
        Thank you much!
        Hydropilot
        • T.C.
          • Sep 2009
          • 245
          Why not drill slightly under size and then buy a 5mm ream ?
          Just measure the motor shaft as all are not 5mm, may be slightly under ?
          T.C.
          • Basstronics
            • 2384
            T.C.
            Quoted for truth.
