I now own the following 2 motors and want opinions on the application of each in a CF RC Boatworks 45" mono.
http://www.leopardhobby.com/product/...ionID=01020202 The 910kv version (56x98)
http://www.skyrc.com/index.php?route...product_id=142 The 600/1050 version (55x112)
I will be using a 300amp swordfish when OSE gets some more hopefully and can go to about any voltage with lipos that is necessary.
U R input on this comparison is appreciated
The 600 Kv wiring is on the low side for a "typical" 10S setup but it may allow you to run the larger gas props which are more suitable to this large hull. An x457 will make the boat move but you will have much better luck with a larger gas prop in the x465 to x470 range. The caveat is that the Sky motor is an unknown in the reliability and efficiency department - it may or may not pull the larger gas props at acceptable temperatures, I have no experience with them.
as I don't normally clean up until I finish a project
