Questions about SC700
  • LJH
    • 70
    So I have been running my Cesa with a SC700 in it for a few weeks and it is going great. I am either running some old CP2400 (12 cell packs) or 3S Lipos. I am running a X448 and have water cooling on both the brushes and the can (not sure if I needed brush cooling but it looks cool :p ). The motor is really not much warmer then ambient but that might be caused by the fact that I am running in 35-40 degree water. I broke the motor in before running it by running it at 3V for about an hour in water, the water got a little gray but nothing like when you break in a SP400 motor. SO...anyhow I am looking for a bit more performance, woudl a prop change make a significant diffrence? How about adding a few more cells? How many cells can the SC700 take without drasticley shortening its life? Any tips on some better speed would be appreciated.
    Cheers,
    Jim
  • DuckOfDeth
    • 63
    It will run on 21 cells for about 4-5 seconds before it fries itself. Just a heads up in case you start feeling frisky.
    I ran it all summer long on 14 gp3700's.
    Duck
    It's a small world, but I'd hate to paint it!
      Anything over 12 will result in a shorter life, but if you prop down the impact is reduced. 14 cells with a small enough prop in a free-running boat should be okay. Over 14 cells and the life is definately reduced - but with care you can still get a lot of runs out of it.
      In our club LSO boats we are all running either 700SCs or SS-1s and x645s. The boats are very well set up and run free. The motors are under 110F after 6 laps on a 1/6th-mile course on an 80 degree day. Mine is not watercooled - none of my 700 motors are. My last SS-1 lasted over 2 years and only crapped out when I ran it with too much prop for too long on a 106 degree day and got it up to over 185F!!! Warped the comm and it was never the same again....and you cannot watercool the comm.
      • boater76
        • 574
        I have a 700 as well. I was planning to run 14 cells on it. How much shorter could the motor life be?
        Ken
          On 14 cells the maximum temperature will determine its life. Keep it under 140 degrees and it will last a long time, just comm wear and a little bushing wear (keep 'em lubed). Keeping it cool means a smaller prop and not running for ten minutes. Watercooling really does little to protect the most critical wear part - the armature. Smart setup and use rather than a bandaid will keep it running longer.
          • LJH
            • 70
            Sticking with 12 cells and switching to a X645, what kind of improvments would I see? Because of the rocker the CESA runs very loose so I do not think that will be an issue :p ,
            Cheers,
            Jim
              A lot depends on the cell quality with the 700 motors. Most of our club LSO boats are running 32-36 mph with an x645 or m645...but we are not running "fan packs".
              • Doozie870
                • 970
                Props, you may have your hands full defending your title, 32-36mph in oval trim!!
                  Tony had plenty of mph left in his Drifter in LA, but he was a gentleman and left some room for others to hope...
                  • properchopper
                    rcgoatbuild@snotmail.com
                    • 7708
                    re
                    Yup, but wait 'till this years SAWS !
