Seriously, why do we have to use TAPE?
  • kevinpratt823
    • Aug 2012
    • 1462
    With all the technology out there, why the heck do I have to use tape on these hatches? Did they not realize I would be removing them every time I run it to change the batteries? Couldn't they build in some kind of seal? Is it just me?
    Sorry, I had to vent a bit.
    My private off road rc track
  • stadiumyamaha
    • 1371
    Or at least make the hatch rectangular with flats on both the hull and hatch side. Also with no handles or locks close to the taped area. See geico hatch handles.
    • ksm2001
      • Jun 2007
      • 397
      You can make a rubber seal around the hull opening for the hatch to seal on and use some type of fastener to secure it, but for many of us tape is the easiest way to go and seems the most water resistant yet. When my boat is doing 50+ mph and flips, a lot of pressure could force water past a seal. Tape is going across both the hatch and hull and I would say minimizes the chance of a leak the most.
      Tape is cheap, the only problem I have is leaving the hardware store with just the tape.
      • Shooter
        Team Mojo
        • Jun 2009
        • 2751
        Unfortunately, large openings don't lend themselves to easy seals. The large perimeter/area of the seal requires a lot of clamp load which simply isn't possible with a couple hatch locks, etc... Any twist of the hull will cause a leak path. Unless you want to have 40 hatch locks and/or screws around the perimeter, tape is still the simplest most effective solution.
        • Rumdog
          • 6667
          It depends on the hull and hatch. They both need to be rigid enough to not flex in a wipeout, or stuff. Then, you can use a seal and hatch screws. I like tape. still, even with locks.
          • Nutbar
            • Aug 2012
            • 43
            with the OP. It's lame to have to tape the hatch over and over again. We can get a man on the moon but we can't make a strong, easy to use, watertight rc boat hatch? Sad...
            • Jason4636
              • 712
              On my fantasm, I have 4 bolts with a hatch seal on mine. Its never leaked a drop yet.
              On my MG I'm rebuilding, I started with a FG hatch. Then reinforced it with a CF/Kevlar inlay. Then drilled 2 holes in the rear of the hatch, and thru the hull. Then just epoxy some bolt bosses in place. And make sure you us a rubber washer under the bolt head. And get a soft foam weather strip seal. To go on the hull where the hatch will seal down to it. Here's the MG I'm rebuilding now.
              • kevinpratt823
                • Aug 2012
                • 1462
                Now that's what I'm talking about! Nice job, and killer paint!
                • Jason4636
                  • 712
                  Steve Miles at Airbrush Alley painted it. His name on here is "PROPAINTER". I'm gonna start painting the MG this weekend. If I get it done or not, depends if the wife will leave me alone enough to get it done. Its gonna be orange, silver, and black. I got it all wet sanded and ready for paint, hopefully I'm starting on it at 1 p.m. tomorrow when the wife goes to work.
                  On the second pic, I got alittle primer over spray the other day. Before I put the motor in it. O'well this is gonna be my play boat anyways.
                  I know the hatch bolts on the fantasm work great. When I was running it the other day. I flipped it upside down. And it sat like that for a good 2-3 minutes till I got out to it. Not a drop came in.
                  • dana
                    • Mar 2010
                    • 3660
                    [ATTACH=CONFIG]85865[/ATTACH][ATTACH=CONFIG]85864[/ATTACH][ATTACH=CONFIG]85863[/ATTACH]
                    I see you went ahead and primed the whole boat...
                    • dana
                      • Mar 2010
                      • 3660
                      If NASA was designing FE boats, then yes, I'm sure they could make a tape less hatch. By "we" you mean who exactly? Lol I assume youre including yourself in putting men on the moon, in which case you must have the smarts to design the tape less hatch....
                      • Jason4636
                        • 712
                        Yea I said the hell with it and just primed the whole thing.
                        • HTVboats
                          • 936
                          Making a hatch that seals well will take as was stated before a ridgid deck and hatch which will add weight and cost that you won't like either. Way back I remember we used plumbers putty to seal radio boxes. (messy) Someone came along and discovered tape was light,fast and simple and less likely to leak over all the foams,silicones and rubber seals.
                          Mic
                          Mic Halbrehder
                          IMPBA 8656
                          NAMBA 1414
                          • dana
                            • Mar 2010
                            • 3660
                            Originally posted by HTVboats View Post
                            Making a hatch that seals well will take as was stated before a ridgid deck and hatch which will add weight and cost. Way back I remember we used plumbers putty to seal radio boxes. (messy) Someone came along and discovered tape was light,fast and simple and less likely to leak over all the foams,silicones and rubber seals.
                            Mic
                            on another note, plumbers putty works awesome for sealing hardware when installing on new boat. much better than silicone imo
                              I made my own to,
                              But hears some kits.
                              http://forums.offshoreelectrics.com/...more-tape!!!**
                              http://forums.offshoreelectrics.com/...bolt-down-kits
