Does this stuffing tube angle look good?
  • Doug Smock
    • 5359
    Originally posted by D.Smock View Post
    What cells are you using, what prop are you running, got a pic?
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • flyboy320
      • Mar 2008
      • 95
      I'm running 2 2S lipos in series (PolyRC, 4000mah, 25C) with the Sv27 motor, and a 40mm CF prop. I have a 42MM and 45mm prop as well, but wanted to start small, and see how it handles first.
      For a picture of the setup inside the hull, see the last picture on post #11. I don't have a RX battery, just running a CC BEC.
      I was actually also wondering about the strut height. Mine is 3/8" as measured from hull bottom, to centerline of the strut.
      • Doug Smock
        • 5359
        You did a great job on the build by the way.
        Normally ( to get an inital adjustment) you would put the boat on a flat surface and with the hull level (ride attitude) you would set the strut flat down on the table. The strut adjustments I have mentioned with the various setups are for those setups. Motor, prop, battery.
        Since you said the boat got right on plane and you didn't mention it hopping I would think the strut is "in the ballpark".
        I don't know where to tell you to go with the CF props I haven't run any of them.
        Go up in prop and play with the strut settings until you get the best possible handling and speed. Take notes on temp readings and such so you can compare your findings.
        Any chance you can post a video?
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • Doug Smock
          • 5359
          Originally posted by fastbaltek View Post
          how do i find the COG of a hydro hull?
          Rule of thunb for a sport hydro is 1.5 to 2" behind the sponson transoms.
          I have O experience with riggers. Other that pitting for Chris Harris. LOL
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • longballlumber
            • 3417
            Where did you get that turn fin? I like that one!!!!
            • flyboy320
              • Mar 2008
              • 95
              I got it from Fullers. It was very scratched up when I got it, and spent about 1/2 with wet/dry paper to remove most of the scratches and polish it up.
              • Doug Smock
                • 5359
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
