I'm looking to spring for a 21FE outrigger . I know the JAE21FE is out there and highly regarded ? Are there any other's . Would like pre built if possible ? Suggestions for motor and running gear for 4s lipo power.
opinions
Tags: None
I'll make the shamless plug here for the Raptor Riggers: Brian Buass designed and built the Raptor Rigger around P-Spec power systems using a single 4S pack. You can swap out the P-spec motor for a P motor such as a Castle 1415 1Y which fits nicely in its place. Even with a P-Spec system the combo runs in the low 60's with a very conservative prop. Use a more aggresive prop and higher speeds are easily attained. The hulls construction is vacuum bagged fiberglass with the option of full carbon. It uses standard Speedmaster hardware on the transom and comes with a turnfin and bracket.
Very nice clean design that runs exceptionally well. In my humble opinion, it takes a lot more work to get the same performance from a JAE.
Here are a couple pics of Raptor Riggers:
yhst-76205423682632_2136_2745940.jpg153%20001.jpg160%20001.jpg160%20002.jpgAttached FilesTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
Martin, It would be best to discuss options with Brian. I will PM you his contact info.
TylerTyler Garrard
Here are some more pics, I grabbed these off an old thread.
138%20005.jpg142%20007.jpg147%20005.jpg147%20011.jpg148%20002.jpgTyler Garrard
Here are some pics of my P Rigger and Mark Grim's in action.
DSC_4881.jpgDSC_4883.jpgDSC_4884.jpgDSC_4885.jpgMark Grim Raptor Rigger.jpgTyler Garrard
Tyler, Could you P.M. the info as well. I would like to build one over the winter, Thanks.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
I guess the more pics I post, the more boats to sell.....
Here is the rigger in the hands of Brian setting the first sub 20 second FE 2-lap record: http://www.youtube.com/watch?v=QguZfASDE8I&feature=plcp
Here is the same hull with a P-Spec motor instead of P: http://www.youtube.com/watch?v=3hfKewhkvLg&feature=plcp
More pics from the Namba FE nats:
Brian's P Rigger 2.jpgBrian's P Rigger 3.jpgBrian's P Rigger.jpgJohn's P-Spec Rigger 2.jpgJohn's P-Spec Rigger.jpgTyler Garrard
I would ask Brian, but I believe yes.
TGTyler Garrard
Regardless, they are a vital part of the hull's design. It will not run like the videos show without the rear sponsons. They don't slow the boat down for SAW runs either.Are the rear sponsons an option
