Need info for eliminate spark.12s setup
  • Paul21
    • 44
    Read somwhere that there was somthing to use to eliminate spark when pluging in batts to esc with hv but caint seam to.find info. Setup would be 12s40c1000mah leo5692 sf240hv pro twin tks
    You didn't look very hard, a simple search for "spark" will give you loads of anti-spark threads. But in reality the spark is a good idea - it lets you know that your caps are working. If there is no spark then your caps are bad and the ESC will soon blow. Without the spark you'll never know until it is too late. Replacing connectors a couple times a year is a lot cheaper than a new ESC.....
    http://forums.offshoreelectrics.com/...ighlight=spark
    • Paul21
      • 44
      Guess I used to many words in search I even tried to locate my own boat build and it never found yet did search on google and found it anyway tks for input never had anything over 6s so I want to be carefsul wit 12s but see u point . I have old build thread hpr ct04 67 inch cat build will be updating soon been away tks
      • twissted
        • 896
        built in to speed control
        If you look into the fightercat speed controls. The new ones come with it installed.
