Help! which flex drive?
  • Lenner
    • Aug 2012
    • 4
    Hi Guys,
    I really need your help to choose a proper drive train for my Genesis?
    I will use Leopard 4082 1600kv on 6s and Octura props.
    Which flex drive shall i pick?
    propshaft?
    drive dog?
    teflon liner?
    Stuffing tube?
    Prop nut?
    Really appriciate your help
  • iamandrew
    • 576
    Do a search for Genesis builds
    • Lenner
      • Aug 2012
      • 4
      Belive me i have done several but i can not find a good answer
      • SirBudman32
        • Aug 2011
        • 701
        I would go with a 1/4 inch stuffing tube with no liner and a 3/16 (.187) flex. I to changed mine out to run a .150 flex and no I have 2 props at the bottom of the lake. Go with the 3/16 and forget about have fun.
        Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
        • highflyerbill
          • Jul 2011
          • 206
          With the 4082 don't go with anything less the. .187 flex or .072 piano wire shaft .
          • SirBudman32
            • Aug 2011
            • 701
            I still go with a .187, 3/16ths. I have a .72 piano wire and prop at the bottom of the pond. Twisted the wire off at the collect.
            • highflyerbill
              • Jul 2011
              • 206
              Yes and I also have a .187 flex and prop at the bottom of the lake . It can happen . When you run a piano wire setup don't run Teflon liners and gentile bends . Otherwise you will build up excessive heat and something will break . I don't run teflon liners , Just use a 1/4 in. brass tubing for your .187 flex shaft , and grease it up good .
              • Azmarine
                • 81
                I need help here too, I have drives that re to be used with 1/4" drive cable. I plan on using hughey 1/4 but I don't know if I should just use tube/no liner, or tube/Teflon. Also I want to use thrust bearings . Last thing how much gap should be placed between the bearings or drive dog and stinger end? Please help
                That odd moment when you think, "Is RTR the way to go?" Then you see your hard work, and laugh at the thought.
                • Dana W
                  • Mar 2012
                  • 35
                  1/8"
