54" drambuie twin
  • Azmarine
    • 81
    54" drambuie twin
    I'm building my drambuie from the hull up, build is being documented but I'm having trouble the length from the end of my sponson to transom is 150mm I can't find a stinger drive that will put the prop just past it. Should I just have a custom prop dog made that is 15-20mm long? Help please builders with experience in large cats
    That odd moment when you think, "Is RTR the way to go?" Then you see your hard work, and laugh at the thought.
  • ManuelW
    • Oct 2010
    • 786
    Hey,
    german manufacturer MTC produces different large powertrimms suitable for these big cat hulls including a type designed for the use on the 54" Drambui:
    regards,
    Manuel
    • Make-a-Wake
      FE Rules!
      • 6057
      Here's a long one, 105mm
      http://www.ebay.com/itm/Promise-Hobb...item1e710ab1c9
      This one is extendable up to 125mm:
      http://www.ebay.com/itm/FLEXISHAFT-F...item1c188cd09d
      • Azmarine
        • 81
        Ok so I'm going with the hor stingers they are 140mm and they are long enough, I've spoken with someone about his drambuie and they work with some milling. So once they're in ill get to work. Thank for the tips guys keep em coming I need the help.
        • focused
          Dutch Electric Powerboats
          • 237
          The drives from MHZ will fit http://shop.mhz-powerboats.com/Antri...be-CT--03.html
          • focused
            • 237
            For a rudder you can use a MHZ rudder http://shop.mhz-powerboats.com/Ruder...uder-Midi.html and shorten it like i did.
            • drwayne
              • 3012
              Hi
              my drambuie on ice uses the MBP click drives
              here http://www.mbp-rc.de/
              great stingers, adjustable length and very well made.
              HPR make adapters for these to fit their hulls... that's a good review !
              rudder http://shop.rcboatbitz.com.au/index....roducts_id=812
              • Azmarine
                • 81
                So here's what I've ordered so far please tell me what I'm missing.
                HOR stinger for 1/4" cable
                4 large water outlets
                2 dual pickups flush mount
                1 150mm scale rudder
                1 pair cowl locks
                Pair of 8mm-1/4" collets
                2 carbon fiber/aluminum motor mounts
                2 1/4" drive dogs they might have been a bad choice as I haven't been able to get my drive cable due to unavailability.
                I want to get thrust bearings from mhz, along with their tube supports. Tell me what I'm missing.
                • Azmarine
                  • 81
                  Just ordered my twin Proteus 524 monsters today, can't wait to see them next to my infantile excelorin 1/32 scale motor. Should be a nice day when they get here.
                  • scottw
                    • 50
                    Ralph
                    Great choice of hull - take your time with the build - here(OSE) is defenatly a great place for advice
                    this hull is the bomb!!! - - you should see some good speed out of this baby - Tip -make sure the drives are 100% parallel with the Hull or she will run like a dog
                    Good Luck
                    Scotty
                    • Azmarine
                      • 81
                      Oh thanks,I'm trying to pace myself but YouTube makes me want it done ha. What do you mean parallel with the hull? Like zero degrees just flat in line? Like the pics above?
                      • Azmarine
                        • 81
                        Well my twins cam in today, but I'm still waiting on my hardware and other parts.
                        • Azmarine
                          • 81
                          S I've got my rudder in place, my stingers in place, my outlets in place, and inlets cut here's what I'm looking at thus far. The motors aren't mounted but they are monsters barely fit in the sponsons, I might have to go with another mount style. I'm opens to advice.
                          • Azmarine
                            • 81
                            I think I'll tow her with my huge, monster, erevo.
                            • Azmarine
                              • 81
                              And here after polishing. My first time I'm pleased with my work
