Esc Help!
  • RichRC
    • 14
    Esc Help!
    Hey Guys, i need some Advice, i have a Brushed motor---> Motor Specifications :
    - Operating : 6 ~ 9.6V
    - Current No Load : 1A
    - RPM No Load : 9600
    And i was hoping you guys could point me in the right direction on what ESC i should buy, and also what Prop and Rudder system would be good to use. my Hull is Pictured in my post " In the Deep End "
    Any info is good info, as my build is stuck untill i can solve this little Dilema
    Many Thanks RichRC
    • 6057
    I cant personally help you unless you state the motor size.............35 x 50mm, 36 x 57mm etc..............shouldnt need an ESC with more than a 50a capacity most likely
    • RichRC
      • 14
      Physical Dimention :
      - Shaft Diameter : Ø3.15mm (0.13")
      - Shaft Length : 18mm (0.71")
      - Can Diameter : Ø36mm (1.42")
      - Can Lenght : 61mm (2.4")
      - Weight : 204g (7oz)
      - Mounting Screws x2 : M3
      • RichRC
        • 14
        https://www.ebay.co.uk/itm/066-9600R...00770282561%26
        these are the motors ( i bought 2 lol)
          • 6057
          That motor wont pull more than about 12-15 amps propped correctly.
          • ENCORE MAN
            • Jan 2010
            • 1096
            Rich, your motor is most likely a 27 turn motor. The best value on the market IMHO would be a DURATRAX INTELLISPORT AUTO SPOTR at Tower Hobbies for $23. This esc will handle a 20 turn motor. The AUTOSPORT w/REVERSE IS $40 but it will handle a 18 turn motor and give you a little more leeway for larger prop sizes. Good luck BG
            • jkr
              FE Addiction
              • 582
              Many people on my scale forum say that this is the best esc.
              It has 100% forward/reverse
              http://www.ebay.com/itm/RC-Model-Shi...item3f1753b426
              • RichRC
                • 14
                thanks guys i bought the Duratrax intellispeed F/R from a guy in Salt lake City ( maybe one of you guys lol )
                always gratefull of Advice as always (pardon the Starwars reference) i am a humble Padowan Learner RichRC
