1527 1.5D- Delta Force 33
  • morewattsnow
    • Oct 2010
    • 236
    I've got a 1527 1.5D I want to put into a mono on 6s. Having no experience with monos, thought I'd garner opinions- is this motor to big? Will it just torque roll uncontrollably? Any other ideas for a suitable hull? Thanks.
    Fast Electrics Have A Small Carbon Wake
  • Make-a-Wake
    FE Rules!
    • 6057
    I'd rather have too much power than make a motor struggle to get what you want out of it, the extra little bit of weight is easily carried by that motor. You have plenty of rpm's so just use a smaller prop to reduce torque roll.............what are you thinking of....?......m445, x642 would be on the milder side to consider.
    • dana
      • Mar 2010
      • 3660
      I agree with wake, torque roll will be caused more by prop selection than motor size. I would go for it and start with an x642 or m445. You will see lower temps by having a motor that can easily do the job, rather than a smaller motor that you are pushing to get the speeds you're looking for. Example is my df26 on Leo 4074 2200kv. It's a rocket and motor only gets to 90 degrees on a full run at wot on x440/3.
      • gerardobrandao
        • Mar 2008
        • 166
        i was running a df 35 with a 1527 1.5 D and a octura x450 prop.
        no torque roll problems...easy 65 mph....problem is keeping it in the water...with a df 33...you re asking for perfect trim and big mah 6S2P for dont letting him fly....
        best regards
        Sent from my GT-I9100 using Xparent SkyBlue Tapatalk 2
        • morewattsnow
          • Oct 2010
          • 236
          That's about what I figured, folks. I'll use 4 Hyperion 5000 mah 3s wired for 6s so plenty of amperage/weight. Thanks for the prop suggestions- I'll start small and watch amps/temps.
          • dana
            • Mar 2010
            • 3660
            your temps arent gonna be an issue with that motor, more like start with small props to see how the boat itself handles. that motor can take a a pretty good sized prop without issue.
            • Make-a-Wake
              FE Rules!
              • 6057
              Yep, that motor wont even know there's a prop attatched to it LOL.........it may get to 85*
                • 9481
                I agree man..
                I've thought about a NEU 1530 .5D for my PMono DF33 with a X450
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  A Neu 1530 is more powerful than a 2215!!!!!!!
                    • 9481
                    What!
                    serious
                    anyone need a CC1717
