Aquacraft revolt esc issues.
  • stadiumyamaha
    • 1284
    Seems like all I'm doing is lately is screwing around with esc,s.
    Anybody have any experience with a aquacraft esc not working? After I connect the batts all it does is beep every second and won't arm with the throttle. Any way to reset?
    The only way I can get it to respond is to push reverse, it will beep then pull the forward, it will beep and then reverse again until a final beep. At the point it will arm and the motor will start to run away.
    Bad esc or out of calibration?
  • SirBudman32
    • Aug 2011
    • 609
    set throttle trim to max and recalibrate.
    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
    • stadiumyamaha
      • 1284
      I'll try that. Thanks
      • stadiumyamaha
        • 1284
        Your the man. Worked perfectly.
        I don't have much experience with these esc's. I should have thought to do that.
        • SirBudman32
          • Aug 2011
          • 609
          No problem, Glad it worked for you.
