tapered rudder vs. straight?
  • driftah
    • 759
    advantages and disadvantages anyone?
  • Darin Jordan
    • 9446
    A tapered rudder tends to drive the nose down more when it's turned, similar to adding castor to the rudder angle.
    Straight rudders, when straight... don't... For turning, with a straight rudder, if you want to pick the nose up in the turns, you tuck the rudder under slightly. If you want to push the nose down in the turns, you angle it back slightly.
    Darin E. Jordan - Renton, WA
    • driftah
      • 759
      so for a 32 mono a straight is prolly better methinks
      • Darin Jordan
        • 9446
        Generally speaking, I always try to use a straight bladed rudder that can be adjusted for caster angle.
        One of the other aspects of a tapered rudder, however, is that you have more blade chord in the water at lower speeds. As the boat lifts out of the water, you end up with less rudder chord in the water.
        I'd go with the straight rudder...
        • Make-a-Wake
          FE Rules!
          • 6057
          WOW.............I thought the rudder tucked would push the nose down??? Thanks for clearing that up. I have my Rudder tilted back just a bit(bottom farther back than top) and I am spinning out a bit, should I tuck it more???? Thanks!
          • Darin Jordan
            • 9446
            Try it! :)
            Here is a REALLY good read on the entire subject concerning all of the adjustments you can do... it's written by John Finch, the gentleman who designed the WildThing Mono:
            Find information, resources and relevant links for modelpowerboat.com. This domain may be for sale.
            From that article, here is what he shows for rudder angle:
            It's definitely the opposite of what you would think, or at least what I would think, it would be...
            • Make-a-Wake
              FE Rules!
              • 6057
              I will give it a shot next time out, thanks Darin!
              • dana
                • Mar 2010
                • 3660
                I always thought the same thing. I've since tucked all my rudders in.
                • dana
                  • Mar 2010
                  • 3660
                  I think it has more to do with turning. Having the rudder tilted back will cause more lift in the turns I believe
                    Yes, tilting the rudder only has an effect on hull trim when turning. Tilting it back will raise the transom in turns, usually not what you want with a mono but helpful with hydros. Realize that you have to tilt the pivot, not just the blade, so sometimes shims are needed between the rudder bracket and the transom.
                      Thanks for this info. I had forgotten this and have been doing things backwards for some time.
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        Got it!!
                        • dana
                          • Mar 2010
                          • 3660
                          Could you elaborate or show a pic jay? I'm not 100% sure what you mean here. Thanks )
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            I have often wondered why a rudder hinge couldnt be setup like this crude photo I just made which would make it tuck "more" as the rudder is turned due to the angle of the hinge.
                            • dana
                              • Mar 2010
                              • 3660
                              Wait I get what fluid is saying now. I'm a little slow today lol
