Atomik A.R.C. 58" Catamaran owners???
    If you did this,
    Quote.
    I ran the boat with a total of 12s. Two battery's on each side in series - then parallel both sides for a total of 12s.
    Than you were still just running on 6s,
    Not 12s.
    But you had 12000mah on hand for longer run time and better amps for the setup.
    • BILL OXIDEAN
      • Sep 2008
      • 1561
      #107
      If you did this,
      Quote.
      Not 12s.
      Hi! i really like this stuff you guys are doing with the ARC. I have a plan of my own you guys will like : )
        • Finest Racing
          In the Fast Lane
          • May 2013
          • 294
          #109
          If you did this,
          Quote.
          Not 12s.
          Got it. My typo. I am connecting each side in series for the total of 12s.
          Only time there is a 6s power source would be when I am using two battery's.
          • oscarel
            • Dec 2009
            • 2373
            #110
            Quote.
            As Lenny stated this is 6s2p - 6s is the 2 in series and 2p is the 2 sets in parallel, not 12s.
            • oscarel
              • Dec 2009
              • 2373
              #111
              Is the esc rated for 12s?
              • Finest Racing
                In the Fast Lane
                • May 2013
                • 294
                #112
                I have it wired for 12s. I may have wrote it incorrectly. The ESC can handle 12s. I have ran four or five sets through it without a problem. The original ESC was a 120a which was upgraded to 180a.
                The battery's are parallel on each side and then into series to equal 12s. :-)
                  Oscarel,
                  It is a stock 120a or 180a esc and rated at 6s max,
                  And this guy for a Atomik representative, BILL OXIDEAN.
                  It is the blind leading the blind.
                  • Rumdog
                    • 6667
                    #114
                    wow... someone's confused
                    • SloHD
                      Slow Electric Addict!
                      • Apr 2013
                      • 337
                      #115
                      Lets see a video, or pictures of how you have it wired?
                      • Finest Racing
                        In the Fast Lane
                        • May 2013
                        • 294
                        #116
                        Oscarel,
                        Stock was 120a, Now ATOMIK has the 180a in all there kits.
                        The end result is that the boat is setup for 12s. each pair of battery's on each side are in parallel - connected together in series to equal 12s. With this setup I have ran a few packs through. The caps on the ESC were at 115 to 120 degrees after a 4 minute run. Motor temp was always below 100 with the battery's at 120.
                        • Rumdog
                          • 6667
                          #117
                          3s batteries paralleled are still 3s. now run them in series with another bank of 3s in in parallel, you get 6s. And no, Atomik did not supply your boat with a 12s esc.
                          • oscarel
                            • Dec 2009
                            • 2373
                            #118
                            Is it wired something like this? The 180 esc is only rated for 6s and it looks just like the T180 but costs $160!
                            And if you truely hooked them up as 12s the caps would be in orbit by now!
                            Atomik Pro Brushless Marine 180 Amp ESC
                            Specifications:
                            Length: 2.86 in (72.6mm)
                            Height: 1.3in (33mm)
                            Width / Diameter: 2.6in (66mm)
                            Motor or Engine: Brushless
                            Continuous Current: 180A
                            Motor Cell Count: 2-4 Cell LiPO, 6-12 Cell NiMH
                            Input: 2-6 Cell LiPO
                            • Rumdog
                              • 6667
                              #119
                              Atomik.. the next G-Freak?
                                • 9481
                                #120
                                Originally posted by oscarel View Post
                                [ATTACH=CONFIG]104790[/ATTACH]
                                Specifications:
                                Great catch!
