Balaenoptera Musculus. Upgrades?
  • masonis1
    If you cant control it 👍👍
    • 1177
    #76
    Good. Can't wait to see this build. I want to redo mine too.
    When speed isnt the option, change your ways
    • masonis1
      • 1177
      #77
      I want to get back in the hobby everywhere. I want my boats good like they are now and I want my rc10 to be as fast as my boats and I want my crawler to get creepin again and well I want a nitro again.
        Originally posted by seehuusen View Post
        Thanks for your explanation Shawn, really appreciated! :)
        It seems a 4mm setup might be a bit large for what I want, I like the idea of something smaller TBH, especially if I'm going to run it on 3S, I'll need a smaller prop
        How do you know, that the shafts etc will fit into the stinger drive? It seems to me that the drive shaft is connected to the flex shaft, inside the stinger tube?
        If so, are there different sizes of shafts, which then fits the 1/8th flex shaft, which fits a specific teflon liner, that then fit a specific thickness of stuffing tube?
        Also, those bushes, are they needed at both ends of the stinger drive? Should I look for drives with these included, or are they readily available?
        I assume they are there to take most of the wear and tear out of the drive as well as stabilize the prop shaft?
        I get what you're saying Mason, I'm just keen to have all the gear here :D in reality though, I'm currently waiting on a whole heap of gear, but it's all for a new Jet boat build (this boat was bought also, but I've got no hardware yet)
        Hopefully all of it will start arriving over the next few days, and I can start gathering gear for the new Musculus (or 757 High Wind or whatever they are called LOL)
        Sorry for all the silly questions, I guess it will all be revealed in good time (I hope I won't be missing bits though )
        Cheers
        Martin
        Some of the struts will have a pair of bushings,some will have a pressed in steel one,and this is the preferred http://www.offshoreelectrics.com/pro...Sport-20-strut You can replace the bushing easily though they last a long time so long as you get your prop balanced well.If you should get a 4mm setup it can be drilled out to put that bushing in.I did it on my twin Gieco build a bit ago.
        • seehuusen
          • Apr 2012
          • 101
          #79
          thanks for that mate, I think I understand now :)
          I've gone and created a little package from one of the better Aussie sites, $27.95 without postage for the flex bits
          I can't seem to find a stinger or a strudder that would fit?!? Am I understanding it right, do you press in the size bushing you require for the thickness of the shaft you run? Or is there something else that would tell me what would be the right size?
          Cheers
          Martin
          1/8" outer tube $4.00
          http://shop.rcboatbitz.com.au/index....roducts_id=119
          1/8" teflon liner $3.00
          http://shop.rcboatbitz.com.au/index....roducts_id=902
          1/8" flex cable with end $15.00
          http://shop.rcboatbitz.com.au/index....roducts_id=123
          1/8" drive dog $3.00
          http://shop.rcboatbitz.com.au/index....roducts_id=138
          M3 threaded prop nut $2.95
          http://shop.rcboatbitz.com.au/index....roducts_id=713
          • masonis1
            • 1177
            #80
            You'll need a motor shaft - 1/8 adapter connector.
            • Southwest
              • 274
              #81
              this is for the best, strutter, pass!
              • masonis1
                • 1177
                #82
                I have a turnigy 2700 where it has a heat sink built in. If you lay the battery sideways it works nice. Or straight.
                • seehuusen
                  • Apr 2012
                  • 101
                  #83
                  thanks mate, I believe it comes with it
                  From the site:
                  $15.00
                  300mm long complete with prop end.
                  Thanks for the setup suggestion South Fork
                  Correct me please if I'm wrong, but .130 = ~3.3mm and 1/8 inch = ~3.17mm, to me suggests that they are very similar in strength?
                  Either way, if someone points me in a direction of a "kit" with all bit included, I'd just go that way...
                  I understand all the pieces that go into the drive train now, but I don't really understand the sizes and what fits together...
                  Looking at HK for bits, I find nothing of interest, e.g. a 4mm flex shaft, but none of the other bits... they suck! :p
                  Cheers
                  Martin
                  • Southwest
                    • 274
                    #84
                    This is for the best, strutter, i'll pass.
                    • masonis1
                      • 1177
                      #85
                      Are you going to post a video on 3s?
                      • seehuusen
                        • Apr 2012
                        • 101
                        #86
                        Hey Mason,
                        I've already pulled the boat down :D (and even sanded it as well!!)
                        I'm thinking those two toy motors, might end up in a little cheap as chips hydrofoil :D
                        Damfurst already posted a vid up of the boat on 2S and 3S: http://www.youtube.com/watch?v=qVCHi...ature=youtu.be
                        Cheers
                        Martin
                        • masonis1
                          • 1177
                          #87
                          Lets see some pics!!!!
                          • seehuusen
                            • Apr 2012
                            • 101
                            #88
                            hahaha, OK OK OK :D
                            I started a new thread, only to realize it was on RC Universe I had done it... do'h :p
                            http://www.rcuniverse.com/forum/m_11287828/tm.htm
                            I could start one here as well, but didn't want to spam Nutbar's thread
                            • masonis1
                              • 1177
                              #89
                              Looks good bud. Make sure you fill those holes good.
                              • seehuusen
                                • Apr 2012
                                • 101
                                #90
                                hell yeah, those holes would cause quite a drag I reckon
                                What do you think about motor size, some people go smaller than what you did...
                                I found a 3200KV 2860 sized motor, which should do the job in theory... I'm just wondering if the size of the motor and thus extra power is required/ utilized?
