T-120 doa
  • rstarny
    • Apr 2012
    • 43
    T-120 doa
    still a little green in the boating world but i have a revolt stock motor but have put a T-120 ESC in. friday run the boats with a x442 prop, 4s 5000 mah (crazy chime walk) but in less than a minute dead in the middle of the pond. When i got it in (15-20 minutes later) poped the top and the ESC was still to hot to touch almost, once cooled still does not work so i assume shot. i believe it was not getting any water as it has a separate pick-up but believe was not getting water at speed. does this sound right and is the esc DOA
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5195
    What boat? ...never heard of a revolt motor... specs please...and yes your ESC is toast.
    Douggie
      • 6057
      That speedo should come in at 120* or less right after a run, if it sat and was still very hot it wasnt getting cooling, sounds like it could be dead. Are the Capacitors bulged on the ends?
      • rstarny
        • Apr 2012
        • 43
        Douggie
        aquacraft revolt .... factory motor and i figured ESC was shot
        • 1945dave
          • Mar 2012
          • 295
          Well, what have you found out? Is your T-120 really toast? I know several guys said it would be but just to give you some hope I still think you have a shot. Cut-off the shrink wrap. Check all your solder points. If you heated it up pretty good I have seen solder connections let go. Nothing to loose, check it out. The T-120 has a electrical thermal link component on the circuit board that can open up. Solder a bridge across it and you might save the ESC. , you have nothing to lose.
          Dave
            • 6057
            I guess I'll take another shot at an answer about the caps...................????
            • rstarny
              • Apr 2012
              • 43
              Dave
              i will give it a look as you say nothing to lose
              thanks
                • 6057
                Either you are ignoring my help or i'm on your ignore "listing"
                Why post and ask for help and I take the time to respond twice trying to help and you dont even acknowledge that I did..................you need to learn some ettiquitte here on the forum..............you a kid?
                • rstarny
                  • Apr 2012
                  • 43
                  sorry missed the cap ? but no bulge at all it was just supper hot, i do believe the water pick up was not deep enough so at speed no or little cooling water for the ESC
                  • rstarny
                    • Apr 2012
                    • 43
                    took the ESC apart and plugged it in it instantly started getting hot so i would say no saving it
