Arowana 22.5 question
  • gfm1135
    • Aug 2012
    • 170
    I purchased an Arowana 22.5 along with 3660SL 3180kv motor, 125a ESC and a 4000mAh 3s 30c lipo. Will this set up be ok for this boat?
  • andreas83a
    • 1
    How is everything working out for ya? The Arowana hull is really nice looking, where did you buy it? and how did it run with the 3660Sl motor?
    I am using a 3660sl 3180kv motor with a 4s lipo and a 120a turnigy marine esc in a CESA 1882 hull and the boat jump off the water at half throttle.
    The cesa hull is ABS plastic so its very light weight, about 3 pounds or 1.4kg The hull is 36 inches long.
    Tested the boat for the first time today and well fast as hell but no stability at all. :)
    • drwayne
      • 2977
      I just sold my arowana 22.5
      baby leo 2645 with a car esc)fan) gave fwd/rev !
      2 x 3S2200 as saddle packs to get everything balanced.
      Worked a treat and it was a real ripper ~25-30 mph !
      • gfm1135
        • Aug 2012
        • 170
        I am still in the building stage with the Arowana 22.5. I switched and am putting a leo 2860 3400kv in it. Hope to have a test run this weekend.
        • SirBudman32
          • Aug 2011
          • 609
          I have a arowana 22.5 with a turnigy 2223 2900kv out runner running a single 3s 2200 and a 35mm prop. Its the wife's boat so I wanted to keep it simple. I would say it does between 25-30 mph. I did have to put trim tabs on it to settle it down but it runs great, fun little boat. Only thing is I can not get it to self right, I have played with the weights they give you and moved everything around inside it but still wont flip itself back over. Thinking about closing the holes up and repainting for her this winter, I wish they offered it with or without the holes.
          Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
          • gfm1135
            • Aug 2012
            • 170
            Did you need to install a turn fin?
            • SirBudman32
              • Aug 2011
              • 609
              No, never had a problem with that it just hopped a lot. just a small set of trim tabs mounted 1/8 inch up from bottom of the hull and then set level with the hull and now she runs nice and smooth with no more bounce.
              • gfm1135
                • Aug 2012
                • 170
                Thanks for the tip. I think I will order a set and install them befor I paint it.
                • gfm1135
                  • Aug 2012
                  • 170
                  What size trim tabs did you use?
                  • SirBudman32
                    • Aug 2011
                    • 609
                    No problem. If you can get some brass sheet you could just make some, they don't need to be very big. About 1 inch wide and maybe 1/2 inch long.
                    • NativePaul
                      Greased Weasel
                      • 2764
                      With the stuff you said earlier that motor is great in Mono1s, very competitive at any level.
                      SirBudman, the LiPo you are using is much smaller than usual, Mono1s normally have a 280gram battery, I bet if you added another 140g of lead under the battery, a bgger battery, or a second battery in parallel, it would turn over.
                      • SirBudman32
                        • Aug 2011
                        • 609
                        No room in boat to put a second battery. Thought about adding more weight to it but it runs to good the way it is.
