found the live mode record option!
More Mystery Controllers
Not trying to steal Steven's business but china dealers have them.My prop hasn't been wet in a while.
We get better service from Steven.ReddyWatts fleet photo
but its not 200 amps continuous. if i have it, it will be rated for what it is.Steven Vaccaro
Why get them from China when Steve will get them to you in about 3 days...when in stock.Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
Ye gads, I would never state that on a forum that OSE funds.Originally posted by calcagno45 View PostNot trying to steal Steven's business but china dealers have them.
Steven has tested the 200 amp esc and states it is capable of 125 amps. This is responsible selling of a product!!!!
Douggie
FO' SHO' Douggie...If it's something Steve doesn't, sell I'll post it...Steve' to much of an honest guy plus his prices with service is beyond exceptionalSamuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
Thanks for standing by me guys.
I have them instock for $62.50.
Right now I have 4 of them. The wording has to be done for the ad. They are strong 125amp esc's. I got the unit to thermal again after trying to burnup the esc, which believe it or not is a good thing. I rather a thermal any day over a
Before I sell it, I will be running some more tests tonight.
Funny note, I mount my test motors and electronics inside the workshop on 2 milk crates that have a piece of 3/4" plywood on top. Than move the setup outside for testing. Reason for this is theres something unnerving about a airplane prop spinning at 20k. I always worry about the sucker coming loose in a 15x15 work area.
. With the neu motor and 150 amps and 14 volts, the prop creates so must thrust they are can be driven around the yard if not held down.
Steven Vaccaro
Ok so you have it in stock trim and it thermals @ 150amps. What about of you installed my monster cooler here
. It's an mhz cooling block thermal epoxied to a thermaltake 12v fan seated on a copper plate with an extra 3/16th cooling line. The fan draws very little current. I'm curious to see how much further it can be pushed with some good cooling. I can send it up
"*Ok so you have it in stock trim and it thermals @ 150amps. What about of you installed my monster cooler here
Image: http://i42.photobucket.com/albums/e343/STOAK/DSC02606.jpg
Image: http://i42.photobucket.com/albums/e343/STOAK/DSC02604.jpg
Image: http://i42.photobucket.com/albums/e343/STOAK/DSC02605.jpg
Image: http://i42.photobucket.com/albums/e3...K/DSC02603.jpg
I failed to mention that my esc was mounted about 8" behind the motor. The motor was spinning a 8" or so airplane prop that moved enough air to drive the test stand around the yard.
And the 1515 was loving all those volts and amps.
One thing I did notice was the packs volts dropped under that load, more than I thought(dont remeber exactly). I will be testing with a newer set of 2s2p to see if the esc likes that better.Steven Vaccaro
WOW! Thanks for the thorough bashing eventhough I clearly stated:
I was simply answering the guys question on quckness if he wanted one that bad.Not trying to steal Steven's business
Trust me I support Steven more than I can afford. And when he is out of stock, I turn to the LHS to support the local business.so how soon do you think we can see the 200amp?My prop hasn't been wet in a while.
Your intent is understood. Most guy’s as a rule use a little more discretion when directing folks else where for out of stock items “IE” PM. Your case is not so bad. It’s not like you plastered a direct link in the open forum like some people do.
Thats exactly why I stated it like I did. Thanks for understanding.
BTW, I got one of these from Txboatpilot with watercooling and proofing. And I dont know the data on Amps and all, but my ESC like this runs like a Champ in my 30" Cat hull(9xl, .130 flex, m445, 16 cells or 4s). She hauls butt for a good 5 minutes and is a steady 105-110 degrees after a run.
I had it thermal once, my fault tho.My prop hasn't been wet in a while.
With that setup its should last a long time.Originally posted by calcagno45 View PostThats exactly why I stated it like I did. Thanks for understanding.
I had it thermal once, my fault tho.Steven Vaccaro
