Cool $4 TX mod..........no more AA Batts for me!!!
  • Make-a-Wake
    FE Rules!
    • 6057
    This little Battery cost me $3.86 and I had the small connector in my "box".
    I was just sick and tired of buying AA batts all the time..............10-15 bucks each time. This 1100mah battery is a Li-fo (3.3v per cell) and it charges up to around 7v and will replace the 4 AA's my 2.4 tx's require. This mod took me 5 minutes and will save alot of $$ as i did it with my other 2.4 as well. I also got some small 3s Lipos to mod my 8 AA cell FM tx's for road rigs. The stock 4 AA batt holder will just come out when you take the TX apart.
    Pic1. Take radio apart with several small screws
    Pic2. Small RX female plug
    Pic3. Connect to the appropriate wires
    Pic4. Insert batt and foam to fill void
    Pic5. The 1100 2cell Li-fo next to a 5000 3s.
    The Li-fo: http://www.hobbyking.com/hobbyking/s...dProduct=20646
    Good plan, good plan.I still have three living sets of Energizer 2200 nimh but when they are no longer good that looks like the next lineup.
    • Make-a-Wake
      FE Rules!
      • 6057
      Thanks Sri, I'm sure others have done this or there may be a packaged "mod" deal you can buy, I posted cuz it was cheap and because some out there have not seen it done i would imagine.
      • HYDROJERRY
        • Jan 2010
        • 2709
        Good work bud,, i have the same broplem and with the same controllers, maybe i should do the same to all mine,,,does it have to be a Li-fo,, or can it be a Lipo with the same ratings??? I dont no anything about Li-fo's...
        • Make-a-Wake
          FE Rules!
          • 6057
          Hey Jerry, I used a Li-fo cuz the voltage was closer to 4 "AA" alkilines, fully charged its about 7.2v as opposed to a fully charged 2s Lipo at 8.4v. It works fine and even the little red light for off/on is brighter LOL..................
          I just used a 2s Lipo setting to charge it and I made sure it didnt go over 7.2v by keeping a cell monitor attatched to the lead. I shouldnt have to charge it but about once every couple months i would guess.
          • SirBudman32
            • Aug 2011
            • 701
            nice tip, I have 3 of these radios I will have to do this to.
            Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
            • Make-a-Wake
              FE Rules!
              • 6057
              • oscarel
                • Dec 2009
                • 2373
                Does your charger have A123 setting? This is from Powerlab8 manual for A123 cells:
                "This preset may also be used for LiFePO4 type batteries which have similar charge characteristics."
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  It has a pb option...............whats that?
                  • Foamaholic
                    • 30
                    pb is lead acid, like a car battery.
                    • oscarel
                      • Dec 2009
                      • 2373
                      What charger are you using?
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        I have a few Acucell eights and a Six.
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          Here's a Futaba FM Digital screen Multi memory TX that came with an 8 "AA" cell tray stock. I use this for alot of my land rigs and this sucker EATS batteries like its alive. Got the 3s 1500 Lipo in, had to change the Batt lead to deans cuz it came with some real goofy one and I didnt have a match for the TX side.
                          When I turn it on the display now reads 12.6v............instead of it normally hovering around 11.6v with nearly fresh AA cells.
                          Quite pleased with my little TX upgrade session...............did two FM's and two 2.4ghz's
                          • monojeff
                            • Nov 2010
                            • 2728
                            I bought some AA at lowes a while back set of 100 for $20 I think it was still have a few sets left after the season.
                            Then if I leave it on by accident its no big deal.
                            OSE GIFTING ELF
                            HAPPY HOLIDAYS!!
                            • lectriglide
                              • 540
                              This is what I use for my Futaba 3PK. Can go 3 or 4 outings without a recharge, and best of all NO MOD required. GREAT upgrade.
                              http://www.hobbyking.com/hobbyking/s...poly_Pack.html
