Interesting do you push or pull dead boats with it?
Rescue Boat
We have found it easier to pull. When we pull a boat in with the grappling hook we just go out and turn around the stranded boat and head back to shore. When we pushed a boat in sometimes due to wind or distance it's hard to line up the boat and keep them from slipping off each other. Of course if you use a push or catch rig on the front of the boat pushing a boat in gets easier.
I'm using a Traxxas Blast, towing a gaff (the proboat rescue duck gaff, but towing a tennis ball works well to). The Blast has enough power to bring in a fairly large boat, and the steerable drive makes it easy to maneuver at low speeds. Plus, it is a fun little boat to let the kids play with.
Chief
Have found this sweet craft on Australian Ebay - was thinking about its potential for a rescue boat
using it to tow the tennis ball type of arrangement. Doesn't have reverse, is reverse desirable but not essential? Would appreciate your thoughts & comments
http://www.ebay.com.au/itm/NEW-Doubl...#ht_8069wt_906
All I could say is if you go with that is... Good Luck.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
Originally posted by BHChieftain View PostI'm using a Traxxas Blast, towing a gaff (the proboat rescue duck gaff, but towing a tennis ball works well to). The Blast has enough power to bring in a fairly large boat, and the steerable drive makes it easy to maneuver at low speeds. Plus, it is a fun little boat to let the kids play with.
Chief
For the money , this is the best boat for the job, and the steerable out drive is a huge plus.
