Fantasm CF 41
  • twissted
    • 896
    So Tyler show him what a nice prop looks like.
    Tony,
    70's and maybe low 80's with the right props are achievable in short bursts with that set-up. 90's will probably require more motor or very careful prop and set-up. Regardless, the upper speeds will take a lot of work where as the lower speeds are pretty obtainable even with the set-up a little off.
    Tyler
    twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
    • Make-a-Wake
      FE Rules!
      • 6057
      I would suggest the following power combo:
      Castle 1717's
      Castle Ice 240 ESC's
      6S 45C or better 5000mAh pack per side
      Counter rotating props like Octura X450's
      That is a 70 mph set-up with reasonable amp draw. Prop up to go faster.
      Tyler
      We're basically recommending the same thing since 4092's are very close to being equal to a 1717(45 x 85mm) in power. I also recommended 450's, but the 3 bladers. 4092's will not be as tight to fit in as well.
      • twissted
        • 896
        I found these at a great price. They will go fast.
        http://www.ebay.com/itm/108mm-adjust...item19d496e004
        http://www.ebay.com/itm/108mm-adjust...item20c82a2f40
        • keithbradley
          • 3671
          Tony,
          I would start out with a twin 6S system for the following reasons:
          -There are several good 6S twin combinations that are known to work reliably
          -You can get away with a single 6S pack per side
          -If you have a twin charger you can charge both packs at once.
          If you go 8S or higher you are more than likely looking at 4 batteries in total which also means two chargers assuming you want to charge everything at once. For example two 4S packs in series to produce a single 8S1P pack per side. You also need to make sure you can fit four batteries in there.
          For hardware: Look for a stinger that has a transom mount and an overhang mount. The transom only mounts tend to bend in crashes. A single rudder with twin pick-ups is advised unless you want to use flush sponson water pick-ups. .187" cable should work fine, use with teflon lined stuffing tubes running into the stingers.
          Castle 1717's
          Tyler
          A member on our forum is doing a build similar to this right now, but using Sirius 1717 motors. The 1717s CAN fit in the sponsons of a Fantasm, but it's a very tight fit and will require some creative work to get them angled correctly.
          www.keithbradleyboats.com
          • RaceMechaniX
            • 3024
            True the 1717's are probably a bit of a squeze. Castle 1520's are a similar kv and will fit better if you can find them.
            I thought about building one with a single 2280 for SAW's but that will wait to next year.
            Tyler
            Tyler Garrard
            NAMBA 639/IMPBA 20525
            T-Hydro @ 142.94mph former WR
            • keithbradley
              • 3671
              Tyler
              I plan on building one with twin 1518s and taking it to make some SAW passes at the race in Flint this October. I believe Joel will be taking his twin 1717 powered Fantasm there as well, so it will be interesting to see how they do.
              • Rocstar
                Joel Mertz
                • 1536
                Yes sir...I'll be there! Working day and night to complete this build and get her dialed in.
                • T.S.Davis
                  • 6266
                  Keith, if you're making the trip to Flint I'll likely show up to hang out witcha. That's only an hour or so from me.
                  Noisy person
                  • keithbradley
                    • 3671
                    Cool!
                    This will be my first organized event, so I'm looking forward to meeting some of you guys.
                    • T.S.Davis
                      • 6266
                      I'm sure I'll be able to talk some of the other MMEU psycos to come with. The SAWs are entertaining if nothing else. Slow paced event but fasssst boats. If I ever get this Q sport settled down, maybe I'll bring it.
                      Noisy person
                      • twissted
                        • 896
                        I'm already looking at another boat. The Genesis 1420mm with a pair of SSS 5694 800kv running on 12s 130c and a pair of 400 amp esc's
                        I'm going to sell one of my trailers to do this one.
