Fightercat is a ghost who never answers emails...how's that working out for you?
Fightercat 300a 2-8S ESC blow up
The one I just received from the same seller does not use a plate. See pics it has a large tube soldered to the board on either side of the esc. I plan to add 4 additional capacitors to it also and soak it in corrosion x all weekend.
These things seem real hit or miss. Think I'll stick with the other brands.If my boats upside down then who owns the one I thought I was driving the last two laps?
Some of the best esc makers in the world use the same cooling technique. The bleed off the heat via the thick copper pcb soldered direct to the cooling tubes. It's very efficient and Schulze, YGE, etc... use this method.
Did you read that link to the other forum? Very informative.
Originally posted by ray schrauwen View PostSome of the best esc makers in the world use the same cooling technique. The bleed off the heat via the thick copper pcb soldered direct to the cooling tubes. It's very efficient and Schulze, YGE, etc... use this method.
don't know what u r talking about what link to what forum help appreciated.
Sorry my bad. A similar thread had this link in it. Very sorry.
Look at the YGE esc. It is the air version but, the only chage for the boat version is the addition of 2 brass tubes soldered to the board.
BTW, HK & HiModel Knocked off the YGE to be YEP or HiModel. HiModel has a marine version of the YGE 120HV. I sold a pair of HiModels in the swap shop, gave up on high voltage, staying at 6S or lower now.
