OSE Pursuit Mono running hot
  • 02ram4by4
    • Jul 2009
    • 43
    Need some help, my pursuit is running hot. Heres the setup ose pursuit 4074 2000 kv 180 esc m445 prop, 4s2p 40c batteries. Not really sure what to do. It has been really hot in michigan water temp is around 75, air temp in the mid 80s. Also there is no binding is driveline. Not sure what im missing
    Dave
  • Diesel6401
    Memento Vivere
    • 4391
    Set the timing around 7.5 - 11.25, make sure you throttle calibrated properly. If the water is petty hot propping down maybe the best solution, but that motor shouldn't have any issue swinging that prop. Make sure you staying wot and keep the runtimes low.
    Samsung Galaxy III via Tapatalk
    - Diesel's Youtube
    - Diesel's Fleet
    • rabosi
      • Aug 2011
      • 209
      I run the exact setup except 30C 3300mah batts and don't have any issues. Is everything getting hot or a specific item?
      • Make-a-Wake
        FE Rules!
        • 6057
        Yeah, whats hot and what is the exact temp of the hot item(s). That combo should work with the 2000kv, the 2200 doesnt like an m445. Try propping down to an x442.
