corrosion x
  • meangenesracing
    • 1332
    corrosion x
    sprayed my castle hydra hv200 esc 24 hours ago should i clean off the excess corrosion x that has not driped off from hanging thanks, geno
  • Serpents811
    • Oct 2011
    • 381
    • Jason4636
      • 712
      I use corrosion x on all my electronics. I don't wipe off any of the excess
      • RandyatBBY
        • 3943
        Strange I have used it on my Schultz's works great! I use it on all my electronics too. Never a glitch.
        Randy
        BBY Racing
          I've used CorrosionX on my electronics - receivers, servos, ESCs - for years with zero issues. I flood the boards, shake off the excess and let it air dry. It can be removed for repair, unlike many of the "conformal" coatings. Too, it is cheap and easy to re-apply.
          • gyrotron
            • 499
            Originally posted by Serpents811 View Post
            Please explain the appropriate use of corrosion x
            • driftah
              • 759
              I fill a cup with the liquid then dip whatever exposed electronics in it then drip dry then use,It actually eats prior corrosion and prevents further corrosion,works amazing on stuff even in the snow...using it for years also heh.it is non conductive methinks also, so zero issues and it wipes off fairly easily...stuff is magic.
              • Jason4636
                • 712
                I'm like the other guys, spray it on let it drip dry for a day. The use it
                • gyrotron
                  • 499
                  When you talk about the use of corrosion x on electronics are you including the motor? Can it be used on the inside of brushless motors after you have previously cleaned it?
                  • JimClark
                    • 5913
                    yup it can
                    Some even buy gallons of it and let the motor soak in it
                    Billy Graham
                    • Jason4636
                      • 712
                      Like Jim said, even on motors
                      • gyrotron
                        • 499
                        Originally posted by JimClark View Post
                        yup it can
                        Can this be considered standard procedure before maiden run?
                        • JimClark
                          • 5913
                          In between maintance for the motors before run for the electronics
                          Billy Graham
                          • RandyatBBY
                            • 3943
                            I have seen several ways to use it.
                            The nitro boys use it on servos in the hot pits in practice when a boat comes in with wet radio box. They pull the servo out and apart spray the motor and circuit board shake off excess and water. Then they put it back together and in to the boat and they work correctly.
                            I like to soak the OPC motors in it after a dunk. It is great to save ball bearings and prolong life of them. On some receivers it is necessary to let drip dry over night. ESC's Spray and use.
                            Randy
                            BBY Racing
                              • 9481
                              Wow!
                              sounds like I need to get some of this stuff..
                              I use the spray electrical tape on my RXs but looks like I can use this stuff on most anything, even motors!
