Advice needed on faster motor to replace stock
  • gyrotron
    • 499
    Hello Guys,
    I need your expertise to select faster/better motor for my good old reliable TT Outlaw Jr boat. I am looking for a direct fit if possible because I am trying to keep the mod at its min since I don't want to modify the whole interior. I have attached the motor specs that are shown on the boat's manual.
    I appreciate everyone's help and contribution
  • Steven Vaccaro
    Administrator
    • 8932
    the problem I've found while working with someone else on this is the mount doesnt seem big enough for a 28mm inrunner with a water jacket. We havent physicly tried it, just going from his measurements. If it would, a 2860 would go nicely with a 90 or 120 amp esc.
    Steven Vaccaro
    • gyrotron
      • 499
      Steve,
      Can you send me a link to your store where I can take a look at the motor you are talking about? Also a link to a recommended motor mount would be great.
      Thanks
      • Steven Vaccaro
        Administrator
        • 8932
        If you want a faster boat with more reliability,
        replace the mount with a ose-80230, This will take modifying the boat and mount.
        the motor with a leopard 3650 2290kv,
        the esc with a seaking 120
        the battery with a 3s 35c 5000mah pack. Use 5.5 bullets on the battery ends. and at least 4.mm bullets on the motor to esc. 5.5 would also be better there.
        Steven Vaccaro
        • gyrotron
          • 499
          I see the motor mount already has water cooling on it. I assume I won't need a water jacket, correct? Will reinforcing the hull be needed for the new motor mount? Thank you Steve.
          • martin
            • 2881
            If your using a Leopard or any other inrunner motor you still need a water jacket on the motor, the water cooled mount is not sufficent to cool an inrunner motor.
