Hey I bought a genesis hull not long ago, just wondering how most people set them up. I have a lot of zippy 5s 5000 mah packs (so 5s 10,000 mah)and would like to run a turnigy 180 esc, any ideas on motor/prop? I would like to go leopard 4082 or 4092 depending on what others have done.
genesis setups, curious
Tags: None
Ya I was thinking the leopard 4082 1800kv, I run two 1600kv motors in my cat and they're great.
Listen to JonD. I have made a mini career at building, rebuilding and modifying the Genesis and can tell you from lots of experience 5S is just about the perfect battery configuration and the Leo 4082 1800kv pushing M445 props nearly perfect as well.Originally posted by iridebikes247 View PostHey I bought a genesis hull not long ago, just wondering how most people set them up. I have a lot of zippy 5s 5000 mah packs (so 5s 10,000 mah)and would like to run a turnigy 180 esc, any ideas on motor/prop? I would like to go leopard 4082 or 4092 depending on what others have done.
Dave
I have a CC 1515 - 2200, T-180 Running (2) 5s 5000 Zippy's with a m445 in my Genesis.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
As far as Amp's I have no idea. I know on a 85 degree day everything was under 105 degree's. As far as performance, First time I really got to run it hit 47.2 on Gps. with strut level with ride pads and offset rudder. Had hard time getting it to go straight, hooked to the right Hard. just did a couple mods to the rudder and strut to try get it to go straight.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
I am running my genesis similarly to the above suggestion.
Leo 4082 1800kv
T180 with extra cap bank
x445
3/16 flex and lined tube
6s2p nanos 6600mah
stock rudder and placement
Here's the link to the rebuild: http://forums.offshoreelectrics.com/...ild&highlight=
I do have some photos of the nanos in the genesis. They barley fit in the sponsons and only fit one way in and out. The most battery the genesis can handle as far as I am concerned.
I think Jon nailed it..................I'd go with the 445Originally posted by JonD View PostMy suggestions if you are wanting to using 5S packs :-
Leopard 4082 1800kV or 2000kV
Turnigy 180 ESC
0.150 flex with 3/16 prop shaft
M445 or M545 prop
Offset rudder
Cheers,
JonNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Zippy has a new line of "compact" lipos. I have a set and like them just fine, I fit 3s2p 6600mah in a 23" DF Mini sniper.
Here are some 6s 3300's in the compact, same voltage and mah as your Nano's, height is much less
Zippy compact:
Length-A(mm) 148
Height-B(mm) 37
Width-C(mm) 44
Turnigy Nano:
Length-A(mm) 145
Height-B(mm) 53
Width-C(mm) 37
http://www.hobbyking.com/hobbyking/s...ipo_Pack_.htmlNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
