Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 36 inch cat. - RcBoaters Forum
36 inch cat.
  • Dziachan
    • Nov 2011
    • 25
    36 inch cat.
    I am building a 36 inch cat. and i need a little insight. I am going to do dual motors and i want to know what motors i should use? I dont want to get too crazy in terms of money, but i want it to be fast. And what ESC would be good to use with these motors? Another question would be do both motors spin the same way or do they need to be counter rotating? I will be wanting to run 6s also.
    Drew
  • 1945dave
    • Mar 2012
    • 295
    Drew
    Read some of the post for the Genesis. Twin power is very popular on these and the Genesis is a 37 inch cat.
    6S and 36 inches will make for a very fast boat and will require careful attention while you are at speed.
    Just for some quick recommendations think Turnigy T-180 or the Swordfish 200 for the ESC's and any good 40 mm motors like a Leo 4082 in the 1200 kv to 1400 kv range.
    Dave
    • keithbradley
      • 3671
      Counter rotate the props.
      What do you consider "fast"?
      www.keithbradleyboats.com
      • Dziachan
        • Nov 2011
        • 25
        I would consider 55-60mph fast. I currently have a stock sv27r and a proboat miss geico. This is going to be my first build.
        Drew
        Holt, MI
        • keithbradley
          • 3671
          Hmm... there are a lot of options here. That speed should be relatively easy. Do you have a budget for ESCs/motors?
          • Dziachan
            • Nov 2011
            • 25
            About four hundred for motors/esc. Five at the most.
            Drew
            • keithbradley
              • 3671
              http://www.offshoreelectrics.com/pro...?prod=leo-3674
              The 1700kv version
              http://www.offshoreelectrics.com/pro...f-sword-200%2B
              http://www.offshoreelectrics.com/pro...?prod=oct-x442
              http://www.offshoreelectrics.com/pro...prod=oct-x442r
              Expect 60mph and relatively low temps with that setup Drew.
              • Dziachan
                • Nov 2011
                • 25
                Keith,
                What kind of results would a turnigy t180 with a leopard 4082.
                Drew
                • Dziachan
                  • Nov 2011
                  • 25
                  What kind of results would that get. Sorry about that.
                  • Alfa Spirit
                    • 2183
                    Here is my Genesis twin setup, 5S is perfect for this size, you can run 4S too but 6S is for bigger hull
                    • keithbradley
                      • 3671
                      Pretty much the same. The 4082 is much larger than what you need though, and the extra weight really hurts the handling of this hull.
                      I went with 3665s in mine for this reason.
                      You could use T-180s instead, I just like the design of the SF ESCs a little better. Either will work.
