Removing Existing Cured Epoxy
  • gyrotron
    • 499
    Hello Guys,
    I just had a mishap with my boat and need to replace the brass stuffing tube. I need to remove and clean the existing epoxy . What is the best and faster way to achieve such task?
    Thank you
  • Rumdog
    • 6667
    heat it up with a hair dryer. Use needlenose pliers and pull it out.
    • martin
      • 2881
      Simular idea you can also use a soldering iron, just warm the tube with the iron & twist & pull out.
      • gyrotron
        • 499
        Will the melted epoxy pull out some of the FG too? I just want to make sure I don't screw up the FG. Any word of caution I should apy attention to when removing the epoxy with the pliers? Thank you.
        • gyrotron
          • 499
          bump
          • Rocstar
            Joel Mertz
            • 1536
            Be careful how much heat you use especially if you use a heat gun. The heat will cause any paint on the bottom of the hull to bubble...Ask me how I know?
            • JimClark
              • 5913
              sand it it should sand fairly easially
              Billy Graham
              • martin
                • 2881
                That why the soldering iron method works better as it consentrates the heat just on the tube & epoxy.
                • gyrotron
                  • 499
                  What sand paper grade do you recommend?
                  • gyrotron
                    • 499
                    Sorry to hear that happened to you.
