Pistix 5 problem ?
  • Andris Golts
    • 508
    Pistix 5 problem ?
    Hi all im running a 19 '' mini mono with a Castle 54 amp Thunder bird aircraft esc a Feigo 10 s 2s lipos a Spektrum DX3S TX and a SR200 RX i installed the Pistix 5 from Mikes sub works in order to use my pistol grip tx but noticed at full speed the motor would stop and start on its own so i tried 2 other motors and same thing i removed the pistix 5 and istalled my DX6i stick radio and rx and everything works fine . Called Mike at Mikes subworks he could not suggest any ideas and sent me another pistix 5 which does the same thing as the previous unit which gives me intermitant high speed. The one thing i noticed with the Pistix plugged into the esc rx lead is total length is 18'' .Could the long rx leads be a issue also tried subtrims and exponantial settings on the tx. What else may be contributing to the intermitant full speed issue? Regards Andris Golts.
