Hi folks. Anyone out there running an endbell heat sink? I'm curious as to how well it works for you.
I found this sink on ebay. It required some mods (milling the slot for the wires) and a few holes to thread in the end bell.
Seems as if the motor heat is a serious limitation for running bigger props in P-spec. I ran some monster props last week and was running mid 50's, but sustaining that is going to require some serious cooling upgrades.
Other idea includes a similar heat sink, but the sink is made of copper and water is in direct contact (going to require some machining time).
Any help/info would be great. Thanks.
" uses to address the over-excited electrons in the endbell and wire entry thermal choke-point. Yes, sports fans, there's no supply of fresh air inside a sealed hull, but according to a law of thermodynamics that I just made up, air accelerating out of the fan is substantially cooler than the residual trapped air.
The "sloshing effect" probably isn't helping either.
