ESC desoldering! AHHHHHHH
    • 9481
    I'm having an issue with my DF33
    my motor wires are soldered directly to the esc to eliminate the resistance of bullets...
    my setup is a Leopard 4092 2080kv on a X447/3 and M545 with 7.5* timing
    things seem ok when I use 5000mah 4s2p 40c packs but when using 5000mah 4s2p 50c packs, two of my motor wires desolder after 2 1/2 to 3 laps...
    motor temps are only 120-125*F and esc temps are the same
    help...
    What make are the 50c packs and are they soft or hard pack ?
      • 9481
      they are soft packs...
      only ran to about 80% after those few laps...
        Water cooling will do nothing to reduce resistance in the solder joints. Apparently the soldered joints have very high resistance. I'd go back to connectors, you can often get a better solder job (more wire contact area) with decent sized bullets than wire-to-wire. The lower resistance packs (50C) are giving up more current, which means more heat in your high-resistance solder joints. Makes perfect sense.
          • 9481
          kinda what I was thinking, less material to flow current.....
          maybe I could strip out more wire, then flatten out the wire before soldering
          cuz I just relized how little wire is touching the other two leads...
          • Alexgar
            • Aug 2009
            • 3701
            Cool setup that's kind weird everything looks good to me
            • RaceMechaniX
              • 3024
              I would suspect you have cold or poor solder joints. The high resistance builds heat and it then becomes easy for the joint to come undone. Try exposing more of the motor leads and use a good iron and good solder. The more contact the wire has with the PCB pad the better conduction will occur and less heat will build up.
              Tyler
              Tyler Garrard
              NAMBA 639/IMPBA 20525
              T-Hydro @ 142.94mph former WR
                • 9481
                the solder joints are about as perfect as it gets... no cold joints at all...
                I'm really beginning to believe I did not have enough exposed wire to begin with...
                so possibly not enough contact with the esc to begin with?
                • drwayne
                  • 3012
                  The esc solder pads have through pcb holes for the output cables
                  Move the esc closer to motor, and pass motor wires through the pcb gates, solder around the wire for total circumference conduction.
                  Better contact and conductivity than what you experience now.
                  Agree with suggestion the side soldered wires have insufficient contact.
                  best of luck !
                  W
                    • 9481
                    best of luck !
                    W
                    nice one man!
                    I'll see if I can get the wires to pass through..
                    I think the holes in the esc bord are to small for the wires..
                    • tryinotocrash
                      • May 2012
                      • 203
                      Are there different temp solders? I would check and see if you could get something with a higher melting point?
                      Don't forget to put your brain in gear before you engage your mouth! Thanks Dad!
                      • puttekula
                        • May 2011
                        • 85
                        Are those wires from the motor shortened?
                        • drwayne
                          • 3012
                          ah @brushless 55
                          shorter wire length is better.
                          Physical degradation of the solder by vibration fatigue may also explain why them seem to desolder... those long wires would induce a nasty effect to the joint
                          The pcb holes suit AWG12 cable, your motor cables should 'squeeze' in.
                          egs
                          W
                          • motorfixer1
                            • May 2012
                            • 41
                            Did the section of wire that you soldered on to the esc already have solder on it fron the factory?
                              • 9481
                              no...
                              ah @brushless 55
                              egs
                              W
                              what long wires?
                              The wires are actually shorter than the esc...
                              plus way shorter than the original esc wires to
                              this setup has a total of 6 laps on it, there is no degradation..
