New boat!!!
Wow........................sexy gal there!! Thought it was a Genesis knockoff at first but nope, quite a bit different. Screaming for 4082's on 6s!!!!!!!!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Outta be quite fast as-is though...........the 4082's just popped in my head.........................Very niceNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Jan @ knitec has same boat for $650.
Dont know how bad shipping hit you from China...?42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)
You may be disappointed with the speed, as that is a big hull. You will need a lot of battery juice and very good ESCs and the motors may not cut, it might work on lower KV motors and 8S, prop selection etc.
Douggie
Martin was saying to make sure you have some external antenna as the hull will block the signal, some 2.4 ghz systems have a small antenna on the receiver, it would slide right up into the red tube on your boat.Originally posted by twissted View Postthe antanna isn't enough?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
It looks like the boat has a 115mm rudder on it...very small for a boat that size. An upgrade in rudder in probably a good idea. Do you know that you can buy just that hull there too? Sometimes it's best to buy just the hull if you plan on upgrading it anyway. The motors will likely need to be mounted in a different place if you end up upgrading the power system.
Keith, what rudder would you recommend for a pull / pull setup?Originally posted by keithbradley View PostIt looks like the boat has a 115mm rudder on it...very small for a boat that size. An upgrade in rudder in probably a good idea. Do you know that you can buy just that hull there too? Sometimes it's best to buy just the hull if you plan on upgrading it anyway. The motors will likely need to be mounted in a different place if you end up upgrading the power system."There's nothing else I really want to do other than get up and build boats." - Mike Fiore
