I would certainly go with a brushless setup, in boats the brushes wear very fast and the motors aren't the most responsive to cooling. Even cooling the brushes and can isn't enough. I would go with something like a 7l nemesis/ feigao motor and maybe even a hydra 120 or the xpower 100 amp that Steve sells right here. Then something like a x632 prop. That will get you in the ballpark if not dead on.
water cooling.
That is the Supervee system and it is just fine for sport running. It runs on two batteries in series however and I don't know if it will run on 7.2 volts or if you would even want to.Originally posted by phase View Postwhat do you guys think of this system- http://www.offshoreelectrics.com/pro...d=dh-blcomboaq
The aquacraft setup would be great if you were using 12 cells and the other system is a no go, you can buy better stuff from Steve for near the same price or less and get it in 3-4 days not weeks. The nemesis 7l motor and xpower esc either the 70 amp or for the extra few bucks just get the 100 amp. You will need a seperate receiver pack but most use them regardless to ensure the boat stays in control.
sv's esc only goes down to 8 nimh cells. imo for an initial setup run the 27t motor with a x432 prop. later on I would consider either a feigao 540 10s or 7l (3500kv) on 7.2-7.4v). that boat isn't gonna like running a hotter kv(yes it can be done but, you're likely to be seeing the underside of the boat alot).Still waiting for my boat to come in.it came in
Good point by Rex I agree 7.4 volts is plenty for that boat but he also suggests a brushless motor. The 27 turn motor is probably a stock class car motor which will have at least 24 degrees advanced timing and that means even more heat. Gotta start somewhere though so give it a try and post the results.
iirc that boat was designed w/ the 27t 'stock' motor in mind(it does better w/ a 19t 05 motor) the 27t motor would let him get the boat up and running and get some experience w/ setting up the boat w/o worrying overmuch about toasting things.Still waiting for my boat to come in.it came in
