Airdam for shovelnose
  • BHChieftain
    Fast Electric Addict
    • 2051
    I'm messing around with an airdam for my 1/10 shovelnose. I am using 2 large drinking straws stacked on top of each other taped together, then taped to the hull.
    Got a few questions--
    How tall should the airdam be? I could replace the straws with an L-plexiglass design if the straws are too short.
    How far back should the dam be placed in the tunnel?
    Thanks,
    Chief
    The height of an air dam depends on the boat, speed, etc. but the thickness of a single large straw works well for my Sport Hydros when they get flighty. I'd place it 2" behind the beginning of the tunnel.
    • martin
      • 2881
      Speak with Fluid as he uses i believe a single straw on this cat hulls, i know they fit them around 2" back from the tunnel but thats on a cat hull. Speak of the man & he shall appear, thanks Fluid.
      • longballlumber
        • 3417
        Another item is a cutting a replacment wiper blade to the correct tunnel length...
        Later,
        Mike
        • electric
          • 1973
          What do you recommend to attach the straw to the hull? Can you just tape it on to try it out? Not a theoretical question since my whip 40 took off again a few weeks ago.
          • martin
            • 2881
            Yep just tape the straw all the way along its length, no need for more than that.
            • JimClark
              • 5913
              the plastic angle works well some have used the clear angle you can get at home depot that protects sheetrock corners
              Billy Graham
              • monojeff
                • Nov 2010
                • 2728
                I just use clear hockey tape same stuff I tape the hatch up with.
                Put two pieces together and can make it different heights.
                Place one piece on the boat where you want it then fold it over. Then place the other piece ontop of the food and secure it down.
                Instant removable air dame work great.
                OSE GIFTING ELF
                HAPPY HOLIDAYS!!
                • BHChieftain
                  • 2051
                  Thanks for the inputs everybody. FYI I have been using clear hockey tape to attach the straws and it is very secure...
                  I'll try a single straw instead of the 2 straws on my next run.
                  Chief
                  • brushlessfreak
                    • May 2012
                    • 21
                    i use a piece of 3/8 heat shrink tubing elec taped about 2in back from front in my catamarans and it works extremely well.the heat shrink tubing is a little stiffer than the drinking straw.it really makes a huge difference when getting over 50mph,in my opinion.
                    • electric
                      • 1973
                      I cannot wait to try out this straw thing to see how it affects the hydro. Let me ask the group a question. If hydro's are prone to flight at high speeds, why don't they have a "bump" in the hydro tunnel two inches back to resolve the "lift" issue? Especially if the is boat designed to race (50mph +)? Got two extra staws at lunch today. The waiter was perplexed why I asked for them...chuckle.
                        Jim, some do have a "spoiler" in the design - Jesse's new wooden Sport boat has one for example. The best solution is to design less lift in the tunnel, but most of the hulls we use are modified nitro hulls which were never designed for the speeds we are now pushing them - the result is too much lift. The Insane FE-30 was designed as a P-Limited racer and has less lift. I only use a dam on my Limited-powered FE-30 in high wind conditions. With full P power it may benefit from one....
                        • electric
                          • 1973
                          Thanks Jay, this is actually for my Q hydro. You will be seeing me with some straws shortly. When the whip 40 takes flight it is something to see.
                            Yes, the Whips are not designed for FE power and have plenty of lift. Most of the time you can work around it, but given some windy weather....
                            • detox
                              • 2357
                              It would be cool if we could build a windtunnel of some kind. A prop dyno would be cool also.
                              I am currently building a Whiplash 40 Q Sport Hydro. I will try to take out lift when building (leading edges sloped more downward, more weight in sponson tips, heavier batteries, strut adjustment)
