cAN SOMEONE EXPLAIN HOW THE WATER IS RAN ON THE T-180 ESC IN WHAT AND OUT WHAT
Help with how water is ran on the t-180 esc
water can be ran on either of the inlets doesnt matter normally one goes in and a tube connects two at the back and then it exits the side the water goes in but yeah there is no right or wrong way you run the water in or out whatever fits in your boat
I'll add that cooling water is usually (not always) run through the ESC first, then the motor then out of the hull. This way the ESC (the most sensitive part) gets the coolest water. Here is one way to do it, although I prefer to run all water through the T-180 first.
