I have my esc programmed. When I connect the batteries I get a series of 3 beeps continuosly. ESC does not respond. Any ideas? And what is the 4 wire lead for? External BEC? Thanks guys
fightercat 300a ESC
Tags: None
After the beeps hold full throttle for around 7/10 seconds
When the motor kicks in let go then you should be good to go
You need to do this each time you connect the lipos
I think the four wires are for conecting twin escs upFC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
Popeye Hydro T600 1400kv 6s1p
I got two new ones I haven't used yet
I read that they are a bit hit and miss
Work really well or fry on the first run
On 6s you need to keep a close eye on temps
What setup you running it with?FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
FighterCat ESC Instructions (latest version).doc
the plug with the 4 wires are for firmware updates only.
start at 5deg for timing and watch the temps closely.
see the attached latest FC instructions.
