How do you fasten your hardware?
  • Doug Smock
    • 5264
    You can rub it right off the parts Douggie, and your right, it does not adhere well to itself after curing.
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Quicksilver
      • 211
      Originally posted by G Doggett View Post
      Same as Eyekandy I have plywood inside the transom but fasten the hardware with stainless bolts and blind nuts.
      To prevent damage to the transom if you hit something I use a 'breakaway' rudder that pivots on just one bolt and the same with the turn fin.
      Seal the bolts by smearing RTV on the threads.
      Graham.
      same here, but I just use epoxy, instead of rtv, since it's usually right next to me anyway. This way, it locks the thread and seals the hole at the same time and it does unscrew if needed, just snaps loose. I also coat all ply surfaces with epoxy, especially the end grain.
      BOATS CAN FLY AND SHOULD!
      • Flying Scotsman
        Fast Electric Adict!
        • 5190
        Doug, not to belabour a point. How do you remove the silicone from the drilled holes without enlarging that hole and having a weak joint and your point on the transom rotting is duly observed and correct
        Douggie
        • Mich. Maniac
          • 1384
          Douggie, it will literally peel off like a buger,,, really, like a bugar. if it does adhere just rub at it or pick at it, It is very user friendly. I just had to say buger again.
          • Doug Smock
            • 5264
            If there is any left in the screw hole it can be pushed out from the inside, or like the Maniac said, pick it out.
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • SJFE
              • 4735
              Uhhh Huu Huu you said buger. I like the term snot rocket myself.
              • justneedspeed
                • 112
                Originally posted by Eyekandyboats View Post
                tap the hole with a ... tap and you do not need any silicone
                What is this tap you speak of?
                always need just a few mph more
                • Flying Scotsman
                  • 5190
                  Doug
                  Well picking you know at what I have a lot of experience with...thanks lads
                  Douggie
                  • Doug Smock
                    • 5264
                    Taps are used to cut threads, see pic. However, I've never seen one that will cut sheet metal or wood screw threads. Maybe Taylor can post a pic of that unit.
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • Flying Scotsman
                      • 5190
                      Doug
                      Agreed
                      Douggie
                      • SJFE
                        • 4735
                        I don't do any of that. Blind nuts are what I use. After I have every thing installed I epoxy over the entire transom. Done & Done. Diffrent strokes for diffrent folks
                        • z400
                          • 1311
                          blind nuts another word for tee nuts?
                          Z
                          KBB34" Mono - Fast
                          ToySport Triton- Not as fast
                          • tylerm
                            • 310
                            Yeap, best thing IMO.
                            I'm with Graham on this one, just use t-nuts(blind nuts whatever) and use some RTV to seal the threads and that.
                            Tyler.
                            • z400
                              • 1311
                              Tyler.
                              Bingo
                              Z
                              KBB34" Mono - Fast
                              • NativePaul
                                Greased Weasel
                                • 2764
                                I use sexy anodised aluminium screws through either a plywood transom or a plywood doubler epoxyed onto a glass transom and held in with aluminium nylock nuts, with a little silicone under the hardware brackets, in the holes and smeared under the heads of the screws just before I nip them down to keep it all watertight.
