stop a spinning teflon tube
  • ironjaws
    • Jul 2011
    • 286
    Can anyone give me any pointers on how to stop a spinning teflon tube? I cleaned it of lubricants but it still spins a bit. Puzzled at this point. Thanks.
  • martin
    • 2881
    Just wrap some plumbers ptfe tape around the tube in 3- 4 places along its length, this works by the way.
    • detox
      • 2357
      To elemenate teflon spinning. Remove teflon tube and install larger .187 cable and collet. I like Kintecs smaller 5mm x .187 stainless collet. Use lots of lube.
      • RaceMechaniX
        • 3024
        If you can clean the OD the Teflon and the ID of the stuffing tube you can use some CA or some Loctite 638. Eventually both will come loose, but it takes some time.
        TG
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • Heaving Earth
          • 1929
          I let em spin
          • iamandrew
            • 576
            Clean the cable, use spray on glue, holds the tube in place, but still possible to remove it e.g. spray oon quiki grip
