What do you guys use to insulate these connectors? The original ones had like a vinyl tubing that slipped one over the other to protect them from shorting out or getting wet. I am having heat issues and want to upgrade to the 5.5 mm connectors but nothing is mentioned about insulation. Any suggestions would be appreciated.
Insulating the gold bullet connectors?
Or......... http://www.offshoreelectrics.com/products.php?cat=39Originally posted by andym View PostIts called heat shrink avalible at any electronics shop.
Product ID: ss-shrink-58
Shrink Tubing 5/8" Wide
DougLast edited by Doug Smock; 04-28-2008, 10:02 AM.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
I am aware of heat shrink tubing but to disconnect them you would have to cut it off. Other ones have a vinyl tubing (kind of like fish tank tubing but much thinner) that slides one into the other for a tight seal and allows them to be disconnected. If I use heat shrink I might as well not use the connectors and just solder the wires.IMPBA 20481S D-12
