Anyone here running the Radtek 92?
  • Jtun5608
    • 22
    Been in talks with them on buying one,
    Just curious if there are others out there running them. If so what power plants are you running?
    Thanks
  • iamandrew
    • 576
    not sure if anyone here has enough money to get one of them up and running!
    maybe two 56 130s ? if they existed hahahah
    • Jtun5608
      • 22
      I am certainly not made of money, but I am the type that I will save and plan the entire build prior to spending the first dollar.
      I have don't the same thing with my bajas I run.
      Great forum here
        • 7512
        Figure around 3k by the time you are done.
        • properchopper
          rcgoatbuild@snotmail.com
          • 7708
          You might give Mark F a shout at marknosedive@aol.com. He collaborates with Radek on builds.
          • MarkF
            dinogylipos.com
            • Mar 2008
            • 988
            I built one for one of Radeks customers and I used 2 Neu 2230 1y motors, 2 castle HV 200 amp sc. 12s 65000 lipos per motor and 2 6518 prop shop 3 blade props. Speed is in the high 80s. Radek uses Lenner 3080 motors. I'm not sure how well less expensive motors would work in a 40lb boat. There very cool boats thats for sure.
            Mark
            • Jtun5608
              • 22
              Thanks Mark,
              I was also thinking of running the Neu 2230 motors
              • graill
                • 407
                Are those 1925 dollars? Grin.
                • ManuelW
                  • Oct 2010
                  • 786
                  Spending 3K on a 92" is to be honest a "little optimistic".
                  So far most used the LMT 3080 engines, big HV ESC's and some serious amount of cells, up to 12S4P per motor giving a total of 96 cells.
                  You may check the setups listed on Hanspeters website:
                  regards,
                  Manuel
                  • Jtun5608
                    • 22
                    Manuel do you own one of these?
                    I would love to pick your brain!
                    3k is no where close
