Modified Castle Bullet Connectors
  • detox
    • 2357
    I modified my old Castle 6mm bullets to accept the large 8 gauge wire of the Hydra Ice 240 LV controller. As you can see in picture I cut the end open using Dremel and cutoff wheel. I held each one with a regular pair of pliars while i cut. You can also drill the hole larger, but I found drilling more difficult.
    These bullets are not plated, as you can see in picture. I really like Castle bullets even more now
  • Basstronics
    • 2384
    Are those 5.5's?
    My last order I got some that are different from previous orders. I now have received 3 different connectors- but they all work (work together also).
    The last batch the drilled portion was significantly larger and the bullet portion had an actual hole there as well.
    • detox
      • 2357
      These are older 6mm. I cut off the small hole portion on side of plug. Wire opening measures .175"
      How much larger is the wire opening on your newer 6MM bullets. You can measure with drill bit, dial caliper,
      • Basstronics
        • 2384
        I dont have 6's.
        Just 5.5 and 8mm
