Pb 1500 vs aq 1800 ?
  • G-UNIT
    • 971
    OK so the pb 1500kv motor on 6s is the same rpm as the aq 1800kv on 5s so what is your take for the best motor on the impulse 31?.
    The new impulse motor is a 1800kv that states it can handle 6s
    both motors are at 3300 rpm 1500 on 6s 1800 on 5s.
    these figures are from the voltage chart posted on this site, is their a little leaway on these #?
    I didn't know 6s= 2.2 volts. ( sorry, hope you don't mind, no ill intention)
    • Heaving Earth
      • 1929
      lets see
      1500 x 22.2 =33,300 rpm
      1800 x 18.5 = 33,300 rpm
      hmmm i guess the proboat motor will have more torque to swing a bigger prop. just my guess
      • G-UNIT
        • 971
        tlandauer:
        Where did you see me type 6s=2.2 volts ?
          • G-UNIT
            • 971
            Which motor would be more suited to run a m445 m545 m645 ?
            I feel as heaving earth said that the 1500 kv would handle the larger props.
            also run cooler on 6s then the 1800 kv.
            any thoughts ?
              I would expect the 1500 Kv motor to do better, but don't assume that an m645 will automatically be okay. Start with the m445 and check temps after one minute, then two minutes.
              • G-UNIT
                • 971
                Thanks Fluid thats what I'm looking for, I will also be running a t180a esc.
