Insane FE 30 Engine Recomendations
  • abmarine
    • 13
    Ok guys have changed my mind, Am going to run a Turnigy 120 amp ESC will a leopard 3665 will this be ok with this ESC or what would you run to set up a P Spec Set up ???
    Thanks in advance
    Tony
    • TheShaughnessy
      • 1461
      Would start with a spec motor and the esc u mentioned. Build instructions can also be found at insaneboats.com. or just have propperchopper build it and be done with it.
      • properchopper
        rcgoatbuild@snotmail.com
        • 7708
        Tony,
        The most popular motor for a spec rig is the Aquacraft 2030KV motor. The T-120 is mostly the go-to esc, but others of at least 60A will do. Most guys that rig for P-Ltd (spec) will run a .187 shaft so they can drop in a more powerfull motor later on if so desired. NAMBA "spec" rules specify only certain motors - the Leo 3665 isn't on the list although not of concern where you are. (sorry I haven't pm'd back- crazy busy)
        (batt's were incorrectly identified; ran 2 X 2S 5000's in series)
