Waterproofing? Corrosion X or spray electrical tape?
  • Jason4636
    • 712
    What's best to waterproof ESC, servo, RX, motor?
  • SirBudman32
    • Aug 2011
    • 701
    I use the spray electrical tape on everything but motor.
    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
      Use CorrosionX.
      • TheShaughnessy
        • 1461
        Use CorrosionX.
        Second that. I've had failures with the liquid electrical. Was a little hard for me to track down but corrosion x is awesome stuff.
        • Foamaholic
          • 30
          OSE sells it I believe?
          • Basstronics
            • 2384
            http://www.offshoreelectrics.com/pro...hp?prod=corr-x
            Not hard to track down. 45 cans on hand.
            • driftah
              • 759
              works great
              • TheShaughnessy
                • 1461
                Yeah Steve must have just re stocked it. Was out on my last order right before nats. I was also trying to find it locally, which I eventually did. Now I also know who doesn't carry it.
                • martin
                  • 2881
                  The problem with using spray electrical tape, Plasti dip or any of this type coating on esc is it contains the heat in the esc which is bad. Like the others i prefer Corrosion X where you can just repeat the process from time to time ecspecially if it does get wet you dry off & recoat. Graupner also do a specific protection spray called Wet Protect which im about to try as well.
                  • Jason4636
                    • 712
                    Just the regular corrosion x or hd?
                    • martin
                      • 2881
                      Youll find nearly everyone uses the regular one.
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        I use both. Tape on esc/rx/servo and corrosion x on motor
                        Sent from my T-Mobile G2 using Tapatalk 2
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • MR2NR
                          Jet Stream EP
                          • Sep 2011
                          • 160
                          Ive been using LET for three years now and haven't had a problem yet but I am not running anything over 3s and have submerged parts completely. The next boat I will prob go to Corrosion X but for now it's worked for me .
                          Kyosho K.I.T.T.
