newbee? Problem with Hydra 120
  • pettt
    65cobra
    • Oct 2007
    • 7
    Have a drifter s running a hydra 120, 9xl 4s lipo. Ran great today but then started cutting out after about 1/2 trigger. Packs are fully charged, settings are good on the hydra.. Anyone have this problem before with a hydra??? It will run for about 3 seconds at half trigger and then stop. If I return the trigger to nuetral pause it will run for another 3 seconds and stop... thanks....
  • NorthernBoater
    • 811
    What hull, packs and prop are you running? We need more info.
    • pettt
      65cobra
      • Oct 2007
      • 7
      Its a H M drifter s 26' x9' running on 4cell lipos 4900 25c rc polly and a x640
      • jeffm912
        • Apr 2008
        • 153
        Are you using the bec? What radio eqipment? You mean PolyRc packs right? I know some lipos fall below the cut off on a hard start, some are inferior or overrated for their general use.
        • pettt
          65cobra
          • Oct 2007
          • 7
          Yes using the bec on a futaba 3ch, Yes PolyRc 25c Expert Series 25c 50 Burst. Before this had 2 great runs. no heat no smoke. everything working fine. Then I connected a 3 cell lipo or a 6 cell nicad too test, does the same thing, after bench testing a 1/4 trigger after 3 seconds it cuts out. After returning too nuetral it will go too 1/4 trigger aned cut out again?????????????? hanks for reply's
          • jeffm912
            • Apr 2008
            • 153
            Ok at first I was thinking it may be glitching because of using a 4s with bec enabled, but if it does it with everything then... Have you tried to reprogram it via the link? Something may have tripped in the esc. Happened in some of my MGM's a while back.
            Jeff
            • Steven Vaccaro
              Administrator
              • 8724
              I'm will Jeff. Check the lcv cutoff.
              Steven Vaccaro
              • pettt
                65cobra
                • Oct 2007
                • 7
                Do not have the Link, have too do it via the radio. Will check my settings after the Kids and WIFE go too bed. Any opinon what the settings on A hydra 120 running 3 cell- mostly 4cell lipos should be??? thanks too all for the quick Replys in helping someone new too the sport....
                • Doug Smock
                  • 5264
                  Another thing to try is to re-calibrate the ESC to the reciever.
                  I never run my boats to lvco but set the control to 3v/cell.
                  Welcome back Steven!
                  Doug
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
