I am going to do my first scratch build, should I use a stuffing tube with a liner or one without?
Stuffing tube question
Thats one of those things that is personal choice. You will get pros and cons for both. I have never done a build with out using one.
Some guys do some don't simple as that, I have never run a boat with one. Never had any problems so for me I won't change.
IMO they add driveline drag.If my boats upside down then who owns the one I thought I was driving the last two laps?
1/4" works well with 3/16" flex and no liner. You might want to add a short 7/32" piece on the motor end to help keep down water intrusion and keep the flex centered better. It can be soldered in or use a little loctite 603 to secure it. (solder holds up to heat better).
I used to run with teflon liners but after having one snag the flex and start spinning inside the tube gave up on that idea.
I am only just getting back into FE after a 2 year break but thought 1/4 tube was used for 3/16 with a liner or .187 flex and no liner.
3/16 and no liner needs the next size tube down.
Your talking .187" flex but also mentioning 3/16", they are both the same size diam. Getting confusing on what you mean, lets start again. 1/4" o/d tube takes a .187" flex with no liner, 9/32" o/d tube takes a .187" flex with a liner.
Its one of those sprintcat knockoffs on ebay, 30 inch cat, 125.00 shipped, its my first scratch build, I am excited, but I want it to come out good, do you think I should use one of those stuffing tube blocks to put in the tube or just put a slot in and fill around it?
